Salta al contenuto principale
Samsung Chromebook Plus Battery Replacement
Evan Elm
Evan Elm e 2 altri collaboratori
Ultimo aggiornamento il March 4, 2024
2 - 5 minuti
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This guide will show you how to replace the battery for the Samsung Chromebook Plus.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Samsung Chromebook Plus Battery Replacement, Removing back panel screws: passo 1, immagine 1 di 1
    • Remove the 8 PHILIPS#0 screws
  2. Samsung Chromebook Plus Battery Replacement, Removing back panel: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
  3. Samsung Chromebook Plus Battery Replacement, Removing battery screws: passo 3, immagine 1 di 1
    • Use your PHILIPS#0 and remove the 4 screws
  4. Samsung Chromebook Plus Battery Replacement, Removing the battery: passo 4, immagine 1 di 1
    • Lift battery from bottom side first (marked with red line)
  5. Samsung Chromebook Plus Battery Replacement, Finally detaching the battery: passo 5, immagine 1 di 1
    • Detach battery cable grabbing the side and pulling the cable upward.
  6. Samsung Chromebook Plus Battery Replacement, Inserting the new battery: passo 6, immagine 1 di 1
    • Insert the battery and push the plug into the socket downward.
  7. Samsung Chromebook Plus Battery Replacement, Re-inserting the screws: passo 7, immagine 1 di 1
    • Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
  8. Samsung Chromebook Plus Battery Replacement, The back panel gets re-inserted: passo 8, immagine 1 di 1
    • Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
    Excellent tutorial! Replaced the batt on our Samsung Chromebook plus circa 2017-18. Ordered batt from seller on Ebay of new old stock. Thanks so much!
    H Brill - Replica
Conclusione
To reassemble your device, skip steps 1-5.
Altre 7 persone hanno completato questa guida.
Evan Elm
Membro da: 12/31/17
1.023 Reputazione
3 Guide realizzate
6Commenti sulla guida
Great repair guide. Nice to see how easy it is to replace battery.
N ick - Replica
Does anyone know where you can get a replacement battery?
Stanley Fujimoto - Replica
Sadly no, I have no idea, chromebookparts.com doesn't have a part either, haven't found one anywhere yet
Evan Elm -
I managed to find a replacement part, see the parts section at the top of the guide :)
Evan Elm -
thanks for finding the battery part! Awesome job!
JT Cen - Replica
Fantastic guide, This made it so easy, especially the note on the cable which clicks in. Thank you so much for sharing.
Morten Damm - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 30
Tutti i Tempi: 7,245
