Salta al contenuto principale
SAFFUN Wireless N64 Controller Action Button Replacement
Jarious Freeman
Jarious Freeman e 3 altri collaboratori
Ultimo aggiornamento il March 2, 2025
15 - 25 minuti
Moderato
Studente al lavoro
Introduzione
Vai al passo 1
If the buttons on your SAFFUN Wireless N64 controller are not responding correctly for in-game action, then you came to the right place. This guide will help you resolve your controller button issues with a quick and simple adjustment.
The action button on a SAFFUN Wireless N64 Controller sends an input signal when it is pressed to perform a specific function in-game or during pairing.
Cosa ti serve
Strumenti
  1. SAFFUN Wireless N64 Controller Action Button Replacement, Action Buttons: passo 1, immagine 1 di 3 SAFFUN Wireless N64 Controller Action Button Replacement, Action Buttons: passo 1, immagine 2 di 3 SAFFUN Wireless N64 Controller Action Button Replacement, Action Buttons: passo 1, immagine 3 di 3
    • First, flip the controller facing back side up.
    • Unscrew the back end screws on the controller using a Philips #00 Screwdriver.
  2. SAFFUN Wireless N64 Controller Action Button Replacement: passo 2, immagine 1 di 3 SAFFUN Wireless N64 Controller Action Button Replacement: passo 2, immagine 2 di 3 SAFFUN Wireless N64 Controller Action Button Replacement: passo 2, immagine 3 di 3
    • Gently take off the back side of the controller and set it aside to reveal the inner components of the controller.
    • Unscrew the components of the mother board using the Phillips screwdriver in order to access the button layouts.
    • Lift the plastic covers off of the buttons.
  3. SAFFUN Wireless N64 Controller Action Button Replacement: passo 3, immagine 1 di 3 SAFFUN Wireless N64 Controller Action Button Replacement: passo 3, immagine 2 di 3 SAFFUN Wireless N64 Controller Action Button Replacement: passo 3, immagine 3 di 3
    • Next, simply remove the buttons from the device.
    • Adjust buttons as needed to accommodate button control.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 95
