Salta al contenuto principale
Ryobi P235 Trigger Replacement
Paul Sousa
Paul Sousa e 2 altri collaboratori
Ultimo aggiornamento il December 19, 2019
30 minuti - 1 ora
Difficile
Introduzione
Vai al passo 1
Use this guide to replace the trigger assembly in your Ryobi P235 Impact driver if power isn’t getting to the motor while using a fully charged battery.
The trigger assembly is what regulates how much power gets to the motor and what direction the motor spins.
When you reach step 7 and 8, the wires are soldered to the motor so a soldering iron will need to be used to disconnect them from the old trigger assembly and then reattach them to the new one.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Ryobi P235 Trigger Replacement, Battery: passo 1, immagine 1 di 2 Ryobi P235 Trigger Replacement, Battery: passo 1, immagine 2 di 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Trigger Replacement: passo 2, immagine 1 di 2 Ryobi P235 Trigger Replacement: passo 2, immagine 2 di 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Trigger Replacement, Trigger: passo 3, immagine 1 di 2 Ryobi P235 Trigger Replacement, Trigger: passo 3, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Trigger Replacement: passo 4, immagine 1 di 2 Ryobi P235 Trigger Replacement: passo 4, immagine 2 di 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Trigger Replacement: passo 5, immagine 1 di 2 Ryobi P235 Trigger Replacement: passo 5, immagine 2 di 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Trigger Replacement: passo 6, immagine 1 di 2 Ryobi P235 Trigger Replacement: passo 6, immagine 2 di 2
    • Lift the trigger mechanism and other internal components out of the housing assembly.
  7. Ryobi P235 Trigger Replacement: passo 7, immagine 1 di 3 Ryobi P235 Trigger Replacement: passo 7, immagine 2 di 3 Ryobi P235 Trigger Replacement: passo 7, immagine 3 di 3
    • Use a soldering iron to remove the black and red wires connecting the trigger assembly to the motor.
    • Use the soldering iron to connect the new trigger assembly to the motor.
    • Make sure the red wire connects to the lead with the red mark on it.
Conclusione
To reassemble your device, follow these instructions in reverse order starting at step 6.
Altre 2 persone hanno completato questa guida.
Paul Sousa
Membro da: 10/29/19
805 Reputazione
5 Guide realizzate
Un commento
Is the trigger what makes this a brushless motor? Is it possible for the trigger to cause the battery to drain down completely overnight?
Netgazer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,543
