Roller Skate Bearing Replacement
Introduzione
Vai al passo 1These instructions will show you how to remove and replace the ball-bearings inside the wheels of four cornered "quad" roller skates. It is important to clean or replace the bearings regularly so the skates function properly.
Cosa ti serve
Ricambi
Strumenti
Remove the wheel
Grip the nut with the pliers and rotate counter-clockwise until loose.
Remove the nut and the wheel from the axle.
Congratulations! You now have a new set of bearings. Give those wheels a proper spin.
