Salta al contenuto principale
Roccat Tyon omron switch Replacement
marc balemboy
marc balemboy e un altro collaboratore
Ultimo aggiornamento il October 13, 2024
30 minuti - 1 ora
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
If your mouse start to register double-click when you click only once, this might be a worn switch.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Roccat Tyon omron switch Replacement, uncovering the screws: passo 1, immagine 1 di 3 Roccat Tyon omron switch Replacement, uncovering the screws: passo 1, immagine 2 di 3 Roccat Tyon omron switch Replacement, uncovering the screws: passo 1, immagine 3 di 3
    • All screw are hidden below the mouse
    • Peel off the mouse pad to uncover 5 of the 6 screws
    • The last screw is in a hole under the sticker. You don't need to remove the whole sticker to uncover it.
  2. Roccat Tyon omron switch Replacement, remove the screws: passo 2, immagine 1 di 2 Roccat Tyon omron switch Replacement, remove the screws: passo 2, immagine 2 di 2
    • use the screwdriver to remove all the screws
    What screw driver is used to open it?
    Ángel - Replica
    it’s all philips screws, i used a size 0
    marc balemboy -
    Most screws are Ph 1, but the screw holding the mouse wheel LED PCB (see step 5) is a PH 0.
    Kay Drangmeister -
    You do not need to remove the two screws farthest from the cable (marked in green in the image).
    Those two screws hold the illumination acrylic, which is untouched and stays in place during this procedure.
    Kay Drangmeister - Replica
  3. Roccat Tyon omron switch Replacement, separate the top half: passo 3, immagine 1 di 2 Roccat Tyon omron switch Replacement, separate the top half: passo 3, immagine 2 di 2
    • Carefully remove the outer shell, the two halves are still connected by wires.
    • remove the white wire connector carefully
  4. Roccat Tyon omron switch Replacement: passo 4, immagine 1 di 3 Roccat Tyon omron switch Replacement: passo 4, immagine 2 di 3 Roccat Tyon omron switch Replacement: passo 4, immagine 3 di 3
    • unplug the remaining connectors
    • carefully pull-down the Ribbon cable to unplug it
  5. Roccat Tyon omron switch Replacement, free the PCB: passo 5, immagine 1 di 3 Roccat Tyon omron switch Replacement, free the PCB: passo 5, immagine 2 di 3 Roccat Tyon omron switch Replacement, free the PCB: passo 5, immagine 3 di 3
    • remove the last screws and pull the board free
    • the mouse wheel LED assembly is a separate piece you need to unscrew.
  6. Roccat Tyon omron switch Replacement, remove the mouse wheel: passo 6, immagine 1 di 2 Roccat Tyon omron switch Replacement, remove the mouse wheel: passo 6, immagine 2 di 2
    • you need to pull the mouse wheel to the right to get it out
  7. Roccat Tyon omron switch Replacement, remove the old omron switch: passo 7, immagine 1 di 2 Roccat Tyon omron switch Replacement, remove the old omron switch: passo 7, immagine 2 di 2
    • I want to change the left switch.
    • flip the board to unsolder the switch.
    • Only two legs are soldered, this is the third one
  8. Roccat Tyon omron switch Replacement, solder the new switch: passo 8, immagine 1 di 2 Roccat Tyon omron switch Replacement, solder the new switch: passo 8, immagine 2 di 2
    • The new switch replace the old one not working.
    • The button should be on the left
    • I used a slightly different switch (D2FC-F-K(50M)). The official one is a D2FC-F-7N(RT)
    resource to decide on which switches to choose for a certain feel or noise
    mouseclub.co/pages/mouse-switch-guide
    THED4NIEL - Replica
Conclusione
Altre 8 persone hanno completato questa guida.
marc balemboy
Membro da: 10/13/20
447 Reputazione
1 Guida realizzata
1Commento della guida
Greetings,
Would you happen to know the part number for the x-celerator paddle potentiometer replacement?
Thanks!
Enrique Rumbo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 108
Tutti i Tempi: 4,389
