Salta al contenuto principale
Retroid Pocket 3 LCD Screen Replacement
Troy
Troy e 4 altri collaboratori
Ultimo aggiornamento il 12 giu 2024
40 minuti
Difficile
Immagini Non Adeguate
Necessarie Immagini Migliori
Passi mancanti
Introduzione
Vai al passo 1
If your screen on your Retroid Pocket 3 is damaged showing: dead pixels, touch malfunction, flickering screen, black spots, lines, discoloration, a totally black screen or cracks on the screen, your LCD screen needs replacement. Follow this guide that will take you step by step on how to replace your LCD screen on your Retroid Pocket 3. This process will take approximately 40 minutes, and the tools required for this project are listed in the guide.
Cosa ti serve
Ricambi
Strumenti
  • Spudger
    Spudger
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Phillips #00 Screwdriver
Mostra di più…
  1. Retroid Pocket 3 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
  2. Retroid Pocket 3 LCD Screen Replacement: passo 2, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 2, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
  3. Retroid Pocket 3 LCD Screen Replacement: passo 3, immagine 1 di 2 Retroid Pocket 3 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
  4. Retroid Pocket 3 LCD Screen Replacement: passo 4, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 4, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
  5. Retroid Pocket 3 LCD Screen Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
  6. Retroid Pocket 3 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
  7. Retroid Pocket 3 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Unclip and remove the one ribbon cable on the left.
  8. Retroid Pocket 3 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
    There is one more ribbon cable that is not called out on this diagram. Right side, between the two in step 8. Appears to be a 5 pin ribbon cable going up into the connector.
    Chris Fulton - Replica
  9. Retroid Pocket 3 LCD Screen Replacement: passo 9, immagine 1 di 2 Retroid Pocket 3 LCD Screen Replacement: passo 9, immagine 2 di 2
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
  10. Retroid Pocket 3 LCD Screen Replacement: passo 10, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 10, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 10, immagine 3 di 3
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
  11. Retroid Pocket 3 LCD Screen Replacement, Button Pad: passo 11, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement, Button Pad: passo 11, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement, Button Pad: passo 11, immagine 3 di 3
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
  12. Retroid Pocket 3 LCD Screen Replacement: passo 12, immagine 1 di 2 Retroid Pocket 3 LCD Screen Replacement: passo 12, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
  13. Retroid Pocket 3 LCD Screen Replacement: passo 13, immagine 1 di 2 Retroid Pocket 3 LCD Screen Replacement: passo 13, immagine 2 di 2
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
  14. Retroid Pocket 3 LCD Screen Replacement: passo 14, immagine 1 di 1
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
  15. Retroid Pocket 3 LCD Screen Replacement: passo 15, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 15, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 15, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
  16. Retroid Pocket 3 LCD Screen Replacement: passo 16, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 16, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 16, immagine 3 di 3
    • Carefully pry up the silicone button pad with a Spudger tool.
  17. Retroid Pocket 3 LCD Screen Replacement, Trigger Button: passo 17, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: passo 17, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: passo 17, immagine 3 di 3
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
  18. Retroid Pocket 3 LCD Screen Replacement: passo 18, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 18, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 18, immagine 3 di 3
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
  19. Retroid Pocket 3 LCD Screen Replacement, LCD Screen: passo 19, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: passo 19, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: passo 19, immagine 3 di 3
    • Using the Spudger tool, remove the two speakers at the bottom of the device by gently prying them out.
    • Speakers are held by double-sided tape.
  20. Retroid Pocket 3 LCD Screen Replacement: passo 20, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 20, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 20, immagine 3 di 3
    • Remove the joysticks by unscrewing the two 3.5mm screws with a Phillips #00 screwdriver.
    • Remove the metal backplate from the front casing of the device by unscrewing the ten 3.5mm screws using the Phillips #00 screwdriver.
    • Carefully lift the ribbon cable from the metal backplate
Conclusione
Troy
Membro da: 02/08/24
85 Reputazione
1 Guida realizzata
1Commento della guida
Hello. Can you tell where I can find a new replacement screen?
Aliaksandr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 113
Tutti i Tempi: 1,313
