Salta al contenuto principale
Retroid Pocket 3 LCD Screen Replacement
Cosa ti serve
  1. Retroid Pocket 3 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    Chiedi a FixBot
    Aggiungi Commento
  2. Retroid Pocket 3 LCD Screen Replacement: passo 2, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 2, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Retroid Pocket 3 LCD Screen Replacement: passo 3, immagine 1 di 2 Retroid Pocket 3 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    Chiedi a FixBot
    Aggiungi Commento
  4. Retroid Pocket 3 LCD Screen Replacement: passo 4, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 4, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. Retroid Pocket 3 LCD Screen Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
    Chiedi a FixBot
    Aggiungi Commento
  6. Retroid Pocket 3 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
    Chiedi a FixBot
    Aggiungi Commento
  7. Retroid Pocket 3 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Unclip and remove the one ribbon cable on the left.
    Chiedi a FixBot
    Aggiungi Commento
  8. Retroid Pocket 3 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
    Chiedi a FixBot
    Aggiungi Commento
  9. Retroid Pocket 3 LCD Screen Replacement: passo 9, immagine 1 di 2 Retroid Pocket 3 LCD Screen Replacement: passo 9, immagine 2 di 2
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
    Chiedi a FixBot
    Aggiungi Commento
  10. Retroid Pocket 3 LCD Screen Replacement: passo 10, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 10, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 10, immagine 3 di 3
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
    Chiedi a FixBot
    Aggiungi Commento
  11. Retroid Pocket 3 LCD Screen Replacement, Button Pad: passo 11, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement, Button Pad: passo 11, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement, Button Pad: passo 11, immagine 3 di 3
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
    Chiedi a FixBot
    Aggiungi Commento
  12. Retroid Pocket 3 LCD Screen Replacement: passo 12, immagine 1 di 2 Retroid Pocket 3 LCD Screen Replacement: passo 12, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    Chiedi a FixBot
    Aggiungi Commento
  13. Retroid Pocket 3 LCD Screen Replacement: passo 13, immagine 1 di 2 Retroid Pocket 3 LCD Screen Replacement: passo 13, immagine 2 di 2
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
    Chiedi a FixBot
    Aggiungi Commento
  14. Retroid Pocket 3 LCD Screen Replacement: passo 14, immagine 1 di 1
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  15. Retroid Pocket 3 LCD Screen Replacement: passo 15, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 15, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 15, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  16. Retroid Pocket 3 LCD Screen Replacement: passo 16, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 16, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 16, immagine 3 di 3
    • Carefully pry up the silicone button pad with a Spudger tool.
    Chiedi a FixBot
    Aggiungi Commento
  17. Retroid Pocket 3 LCD Screen Replacement, Trigger Button: passo 17, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: passo 17, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: passo 17, immagine 3 di 3
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    Chiedi a FixBot
    Aggiungi Commento
  18. Retroid Pocket 3 LCD Screen Replacement: passo 18, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 18, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 18, immagine 3 di 3
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    Chiedi a FixBot
    Aggiungi Commento
  19. Retroid Pocket 3 LCD Screen Replacement, LCD Screen: passo 19, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: passo 19, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: passo 19, immagine 3 di 3
    • Using the Spudger tool, remove the two speakers at the bottom of the device by gently prying them out.
    • Speakers are held by double-sided tape.
    Chiedi a FixBot
    Aggiungi Commento
  20. Retroid Pocket 3 LCD Screen Replacement: passo 20, immagine 1 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 20, immagine 2 di 3 Retroid Pocket 3 LCD Screen Replacement: passo 20, immagine 3 di 3
    • Remove the joysticks by unscrewing the two 3.5mm screws with a Phillips #00 screwdriver.
    • Remove the metal backplate from the front casing of the device by unscrewing the ten 3.5mm screws using the Phillips #00 screwdriver.
    • Carefully lift the ribbon cable from the metal backplate
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Troy
Membro da: 02/08/24
85 Reputazione
Una guida realizzata
1Commento della guida
Hello. Can you tell where I can find a new replacement screen?
Aliaksandr - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 27
Ultimi 30 giorni: 83
Tutti i Tempi: 2,371
