Salta al contenuto principale
Resetting Windows 10
Conor Bailey
Conor Bailey e 4 altri collaboratori
Ultimo aggiornamento il 20 ott 2024
30 minuti - 5 ore
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Using Settings, we're going to initiate a Windows reset.
This is the catchall, the nuclear option, this method will fix most, if not every problem with windows 10.
There are many reasons why you may want to reset windows
  1. If your PC is running slow and can't figure out why.
  2. Your concerned that you have a virus and your anti-virus isn't picking anything up.
  3. Vital parts of windows have failed due to a botched update/upgrade.
  4. The stars have aligned and you had a vision telling you to do it.
What ever the reason, the process is now simpler than ever with windows 10, follow the steps below to begin!
  1. Resetting Windows 10, Open settings: passo 1, immagine 1 di 2 Resetting Windows 10, Open settings: passo 1, immagine 2 di 2
    • Press Windows + I to open your settings window.
    • Then click "Update & security"
  2. Resetting Windows 10, Recovery: passo 2, immagine 1 di 1
    • From the settings window click "Recovery"
  3. Resetting Windows 10, Reset: passo 3, immagine 1 di 1
    • From the recovery menu click "Get started" under "Reset this PC"
  4. Resetting Windows 10, Keep or Remove your files: passo 4, immagine 1 di 1
    • You are then asked to choose one of two options. Pick one that would best suit your needs.
    • Keep my Files: This will keep any files you have stored in the windows Documents, Pictures and Videos folders etc. This will result in a fresh install of windows but keep all your files.
    • Remove everything: This will completely refresh the windows OS, free from any files or apps that where on before, any files stored on other drives or partitions will remain. Make sure you back up any data you want to keep before choosing this option.
  5. Resetting Windows 10, A few more clicks: passo 5, immagine 1 di 3 Resetting Windows 10, A few more clicks: passo 5, immagine 2 di 3 Resetting Windows 10, A few more clicks: passo 5, immagine 3 di 3
    • After a short wait, windows will let you know what apps will be uninstalled. Click "Next"
    • After reading a quick overview of what is about to happen. Click "Reset"
  6. Resetting Windows 10, Lots of loading: passo 6, immagine 1 di 3 Resetting Windows 10, Lots of loading: passo 6, immagine 2 di 3 Resetting Windows 10, Lots of loading: passo 6, immagine 3 di 3
    • The rest is automatic and will take some time. Make yourself a cup of tea and relax.
  7. Resetting Windows 10, Finishing touches: passo 7, immagine 1 di 3 Resetting Windows 10, Finishing touches: passo 7, immagine 2 di 3 Resetting Windows 10, Finishing touches: passo 7, immagine 3 di 3
    • Once the reset is finished just log in as normal.
    • Windows will make a few final changes, and your done!
    • On your desktop will be a html file that will contain all the apps that were removed.
Conclusione
Altre 19 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Conor Bailey
Membro da: 04/27/16
8.148 Reputazione
2 Guide realizzate
Tech Haus Membro di Tech Haus
Business
1 Membro
13 Guide realizzate
2Commenti sulla guida
Really nice information to the techies and readers... who want to do the job yourself.. I m sure anyone can reset the laptop , if he she follows the instructions mentioned here.
ncrsystemsolution - Replica
what if you forgot your password and you won’t open it. you want to reset your laptop what should i do?
John Paul - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 48
Tutti i Tempi: 4,201
