Salta al contenuto principale
Replacing accessory belt and rollers
AntonioTwingo
AntonioTwingo e un altro collaboratore
Ultimo aggiornamento il February 29, 2024
Nessuna stima
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Applicable to all engines (H4D and H4Bt)
This tutorial is shown on an H4D. The procedure is identical for the H4Bt.
Replacement of the accessory belt and pulleys is recommended every 120,000km or 6 years. This operation should be performed with the vehicle slightly elevated.
  1. Replacing accessory belt and rollers, Accessing the engine hood: passo 1, immagine 1 di 1
    • Open the trunk.
    • Put aside the trunk carpets.
  2. Replacing accessory belt and rollers, Acessing the engine compartment: passo 2, immagine 1 di 1
    • Unscrew the 6 T50 screws by hand or using a wrench and a socket.
    • Lift and put aside the engine hood.
  3. Replacing accessory belt and rollers, Remove the accessory belt protective cover: passo 3, immagine 1 di 1
    • Remove the 4 screws from the belt protection cover using a 10mm wrench.
    • Remove the protective cover from the belt.
  4. Replacing accessory belt and rollers, Release and remove the accessory belt: passo 4, immagine 1 di 2 Replacing accessory belt and rollers, Release and remove the accessory belt: passo 4, immagine 2 di 2
    • Our aim is to have a colored tensioner like the one shown in the picture and like the new tensioner.
    • Use a 13mm hexagonal wrench and place it on the tensioner.
    • Turn the tensioner clockwise until you can insert a 4mm-thick pin into the hole and lock it in this position.
    • The tensioner is now locked and the accessory belt has loosened. It can now be removed.
  5. Replacing accessory belt and rollers, Replacing the tensioner roller: passo 5, immagine 1 di 2 Replacing accessory belt and rollers, Replacing the tensioner roller: passo 5, immagine 2 di 2
    • Remove the single 13mm hexagonal screw from the tensioner and pull it out.
    • Fit the new tensioner roller, ensuring that the pin is correctly positioned.
    • Tighten the single new 13mm screw to 62 N/m.
    • Keep the tensioner in place for belt replacement.
  6. Replacing accessory belt and rollers, Replacing the winding roller: passo 6, immagine 1 di 2 Replacing accessory belt and rollers, Replacing the winding roller: passo 6, immagine 2 di 2
    • Use a screwdriver to remove the cap from the winding roller.
    • Remove the single 13mm screw from the winding roller.
    • Fit the new winding roller and tighten the single new 13mm screw to a torque of 50 N/m.
  7. Replacing accessory belt and rollers, Replacing the accessory belt: passo 7, immagine 1 di 3 Replacing accessory belt and rollers, Replacing the accessory belt: passo 7, immagine 2 di 3 Replacing accessory belt and rollers, Replacing the accessory belt: passo 7, immagine 3 di 3
    • The idler roller must be in the slack position and tapped. If this is not the case, refer to step 2 to adjust it.
    • Install the accessory belt in the correct position, depending on whether or not the vehicle is fitted with an air-conditioning compressor. Make sure the belt passes correctly over the pulleys.
  8. Replacing accessory belt and rollers, Releasing the tensioner: passo 8, immagine 1 di 2 Replacing accessory belt and rollers, Releasing the tensioner: passo 8, immagine 2 di 2
    • Using a 13mm hex wrench, release the tensioner roller to remove the pin and return it to the tensioned position.
    • Turn the crankshaft pulley two revolutions clockwise with a 19mm socket wrench to ensure that the belt turns and is positioned correctly.
  9. Replacing accessory belt and rollers, Replace belt cover: passo 9, immagine 1 di 1
    • Replace the accessory belt cover and tighten the 4x 10mm screws to 10 N/m.
    • No tightening torque is recommended by the RTA. The torque given is a suggestion.
Conclusione
Felicitations! You've just replaced your accessory belt and rollers!
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
AntonioTwingo
Membro da: 08/24/22
7.005 Reputazione
44 Guide realizzate
5Commenti sulla guida
Hi! Is this good for SCe 75 engines too? I got a Dacia Sandero II with a B4D 411 engine and i was wondering if i could use this guide to change my parts too
Árpád Kis - Replica
Hi ! This tutorial is not applicable to your B4D 411 engine, part number 8201704417. The belt routing on this engine looks very different from the pictures I found online.
Other than than, many parts are different on this engine, including the injectors and all.
However, you might find some useful information on those links:
https://www.catcar.info/renault/?lang=en... (various schematics)
https://www.youtube.com/watch?v=IoF0ixzo... (B4D 422, also known as B4D LS, for Low-Spec)
AntonioTwingo -
Bjr pouvez vous me dire ou ce trouve le calculateur
Lucas - Replica
Bonjour,
Il y a plusieurs calculateurs dans les Twingo III. Pouvez-vous préciser quel calculateur ?
Si vous faisiez référence au calculateur moteur (ECU):
Renault Twingo III Phase 1 (2014-2019)
AntonioTwingo -
Merci bcp pour votre reponse je cherche bien l'emplacement du calculateur moteur car j'ai bien cherché coté droit du coffre dans les garnitures et je n'ai rien trouvé.
Lucas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 270
Tutti i Tempi: 4,999
