Salta al contenuto principale
Removing Nishiki Aero II Front Wheel
Tobias Elder
Tobias Elder e 11 altri collaboratori
Ultimo aggiornamento il December 15, 2023
3 - 5 minuti
Molto facile
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
Use this guide to remove the front wheel from a Nishiki Aero II Road Bike or similar bikes that use a bolt-on axle, which is commonly found on older bikes or single speed city bikes. This guide is not for quick release or thru axles. Bolt-on axles are great for bikes that require simplicity and are better at stopping bike wheel theft because they take longer to remove compared to quick release axles. It is critical that this is done correctly; if not it can result in serious injury to the drop outs on the bike and to the rider if the wheel comes off due to improper installation.
Before using this guide make sure you have the correct size replacement 700c front wheel that has a bolt-on axle.
Cosa ti serve
Strumenti
  1. Removing Nishiki Aero II Front Wheel, Removing Road Bike Front Wheel: passo 1, immagine 1 di 1
    • Turn the bike upside down.
  2. Removing Nishiki Aero II Front Wheel: passo 2, immagine 1 di 1
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Removing Nishiki Aero II Front Wheel: passo 3, immagine 1 di 2 Removing Nishiki Aero II Front Wheel: passo 3, immagine 2 di 2
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Removing Nishiki Aero II Front Wheel: passo 4, immagine 1 di 1
    • Follow the previous steps for the opposite side.
  5. Removing Nishiki Aero II Front Wheel: passo 5, immagine 1 di 1
    • Lift the wheel up from the fork.
Conclusione
Tobias Elder
Membro da: 04/25/13
113 Reputazione
7 Guide realizzate
Cal Poly, Team 21-53, Johann Spring 2013 Membro di Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,199
