Removing JuiceBox from the wall
Nessuna stima
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1It only takes one screw to get JuiceBox off the wall.
On most installations, the JuiceBox is held to your wall using one screw between the two cable glands. Remove this screw.
After removing the mounting screw, lift JuiceBox straight up (parallel to wall) to unlatch it from the wall mounting tab. If you ever sell/give away JuiceBox, keep this wall mount tab with the box!
Quasi finito!
Conclusione
