Salta al contenuto principale
Remove and clean the Whirlpool dishwasher spray arm
Eduardo Mola
Eduardo Mola e 2 altri collaboratori
Ultimo aggiornamento il September 24, 2024
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
This guide helps you through the process of how to replace a faulty or bad Whirlpool dishwasher spray arm in a quick and reliable manner. By following these simple steps, you can restore your dishwasher's poor cleaning performance back to normal.
Having a bad or faulty spray arm can lead to poorly cleaned dishes and potential leaks from the dishwasher itself. It's important to address these issues as soon as possible, as a bad spray arm can impact the overall performance of your dishwasher and lead to more serious problems over time.
  1. Remove and clean the Whirlpool dishwasher spray arm, Spray arm: passo 1, immagine 1 di 2 Remove and clean the Whirlpool dishwasher spray arm, Spray arm: passo 1, immagine 2 di 2
    • Turn off the dishwasher.
  2. Remove and clean the Whirlpool dishwasher spray arm: passo 2, immagine 1 di 3 Remove and clean the Whirlpool dishwasher spray arm: passo 2, immagine 2 di 3 Remove and clean the Whirlpool dishwasher spray arm: passo 2, immagine 3 di 3
    • Remove the lower rack.
  3. Remove and clean the Whirlpool dishwasher spray arm: passo 3, immagine 1 di 1
    • Locate the lower spray arm.
  4. Remove and clean the Whirlpool dishwasher spray arm: passo 4, immagine 1 di 3 Remove and clean the Whirlpool dishwasher spray arm: passo 4, immagine 2 di 3 Remove and clean the Whirlpool dishwasher spray arm: passo 4, immagine 3 di 3
    • Detach the lower spray arm by rotating the base counterclockwise.
  5. Remove and clean the Whirlpool dishwasher spray arm: passo 5, immagine 1 di 3 Remove and clean the Whirlpool dishwasher spray arm: passo 5, immagine 2 di 3 Remove and clean the Whirlpool dishwasher spray arm: passo 5, immagine 3 di 3
    • Detach the top spray arm by rotating the base clockwise.
  6. Remove and clean the Whirlpool dishwasher spray arm: passo 6, immagine 1 di 2 Remove and clean the Whirlpool dishwasher spray arm: passo 6, immagine 2 di 2
    • Clean the spray arm with warm soapy water and a soft brush.
  7. Remove and clean the Whirlpool dishwasher spray arm: passo 7, immagine 1 di 3 Remove and clean the Whirlpool dishwasher spray arm: passo 7, immagine 2 di 3 Remove and clean the Whirlpool dishwasher spray arm: passo 7, immagine 3 di 3
    • Rinse thoroughly and reattach the spray arm to the dishwasher.
    • The longer spray arm goes on the bottom and the shorter one on the top.
  8. Remove and clean the Whirlpool dishwasher spray arm: passo 8, immagine 1 di 1
    • Run a cycle with hot water and a dishwasher cleaner to further clean the interior.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Eduardo Mola
Membro da: 01/16/23
211 Reputazione
1 Guida realizzata
2 Commenti
This is fine for light soil, but if you let the two filters in the bottom of the washer get impeded by slime and food debris, the arms will have food particles inside them and the finer holes of "premium" washers are too small to reverse flush. Any added features in them will make things worse. Soaking in a solution of warm, not hot water with liquid enzyme drain cleaner for several nights may digest the protein and fat and let them pass.
P Schmied - Replica
Thanks or this post. I'm facing this exact problem, upper spray arm holes are clogged with maybe pieces of labels and I can't clear it. I'll try your method.
Rick Cahoon -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 17
Ultimi 7 Giorni: 135
Ultimi 30 Giorni: 511
Tutti i Tempi: 11,153
