Salta al contenuto principale
Remove Dislodged Plug Parts
Michael Pangburn
Michael Pangburn e 2 altri collaboratori
Ultimo aggiornamento il May 9, 2024
10 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This guide is for either replacing the receiver jack/plug or removing parts that have broken off inside the headphones from a plug. Please read it through and make sure you are comfortable with it before attempting the teardown.
Cosa ti serve
Strumenti
  1. Remove Dislodged Plug Parts, Remove Left Ear Cushion: passo 1, immagine 1 di 2 Remove Dislodged Plug Parts, Remove Left Ear Cushion: passo 1, immagine 2 di 2
    • Place the headphones down with ear cushions facing you
    • Cushions are held in by small tabs along the perimeter. Remove by hand
  2. Remove Dislodged Plug Parts, Remove Left Driver Pad: passo 2, immagine 1 di 2 Remove Dislodged Plug Parts, Remove Left Driver Pad: passo 2, immagine 2 di 2
    • Pad is held in by two pieces of double-sided tape. You only need to peel back the left piece, as shown
    • Be careful to avoid tearing the pad
  3. Remove Dislodged Plug Parts, Remove Left Backplate: passo 3, immagine 1 di 2 Remove Dislodged Plug Parts, Remove Left Backplate: passo 3, immagine 2 di 2
    • First, remove the two small philips screws securing the backplate to the body
    • Turn the headphones over and carefully wiggle the backplate away from the body. Use soft plastic tools if necessary to avoid scratching the plate
  4. Remove Dislodged Plug Parts, Remove Plug Circuit Board: passo 4, immagine 1 di 2 Remove Dislodged Plug Parts, Remove Plug Circuit Board: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the two small, shorter philips screws securing the board to the body
    • The board is now held in by vinyl tape (black) and two ribbon cables
    • If you are just removing broken plug pieces, do not disconnect these ribbon cables - be careful not to damage them! Instead, simply lift the board enough to poke tweezers or similar through the plug to dislodge broken bits
    • If replacing the plug, disconnect the ribbon cables (one is soldered in place) from the circuit board and replace the board
    Hi, thats exacrtly the problem I have (broken not functioning plug), but I can not find the spare part anywhere, can you help me ?
    Schwarzti - Replica
Conclusione
Reassembly is the reverse of disassembly - no surprises. Optionally, replace your ear cushions, pads, or double sided tape in the process.
Altre 5 persone hanno completato questa guida.
4Commenti sulla guida
This guide was also useful to push back the pins of the headphone jack, as the plug got loose with the Gaming mic attachment.
Albert - Replica
Does that work for a lose 2.5 mm plug that it’s not making correct contact?
Marcos Ruiz -
Where can i buy the spare parts ?
Term - Replica
Where do we even get another receiver plug?
George “calfilmmaker” - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 101
Tutti i Tempi: 7,708
