Salta al contenuto principale
Razer Basilisk V3 Scroll Wheel Assembly Replacement
Mary Quin
Mary Quin e 3 altri collaboratori
Ultimo aggiornamento il March 3, 2025
25 - 45 minuti
Moderato
Introduzione
Vai al passo 1
It is not uncommon for mice, such as the Razer Basilisk V3, to see mechanical difficulties through wear and tear of the mouse. In order to fix issues such as unregistered scrolls, double scrolling, or general friction, it might be necessary to take apart the mouse and perform a replacement. Additionally, customization and upgrades could also be a reason to replace the scroll wheel.
It should be noted that disassembling the mouse to replace the scroll wheel will most likely damage the mouse skates. Also, it is helpful for users to have knowledge in basic electronics as well as the internal structure of a mouse. This guide will assist in replacing the Basilisk V3 scroll wheel.
Cosa ti serve
Strumenti
Mostra di più…
  1. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Skates: passo 1, immagine 1 di 1
    • Locate each of the skates.
  2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 2, immagine 1 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 2, immagine 2 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 2, immagine 3 di 3
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Backplate: passo 3, immagine 1 di 1
    • Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 4, immagine 1 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 4, immagine 2 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 4, immagine 3 di 3
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 5, immagine 1 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 5, immagine 2 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 5, immagine 3 di 3
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
  6. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: passo 6, immagine 1 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: passo 6, immagine 2 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: passo 6, immagine 3 di 3
    • Use the flat end of the spudger to pop-out the scroll wheel assembly.
    • Make sure you are careful when removing the assembly since it is still connected to the device with a ribbon cable. If you pull too hard the cable could break.
  7. Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 7, immagine 1 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 7, immagine 2 di 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: passo 7, immagine 3 di 3
    • Pull up on the top half of the cable connector and pull the cable from the connector.
    • The connection pins on the wire face towards the scroll wheel assembly housing. When reassembling, make sure the connectors on the cable are facing the correct direction.
Conclusione
Altre 2 persone hanno completato questa guida.
Mary Quin
Membro da: 03/20/24
252 Reputazione
2 Guide realizzate
1Commento della guida
Where can I buy this complete spare part?
Van4ESss - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 18
Ultimi 7 Giorni: 95
Ultimi 30 Giorni: 371
Tutti i Tempi: 2,549
