Salta al contenuto principale
Razer Basilisk V3 Switch Replacement
Brendin Costa
Brendin Costa e 3 altri collaboratori
Ultimo aggiornamento il May 1, 2025
15 minuti
Moderato
Introduzione
Vai al passo 1
This guide outlines the steps for replacing the main left and right-click buttons on the Razer Basilisk V3 gaming mouse. Whether the buttons have become unresponsive or physically damaged, this guide will assist with installing new button modules to restore functionality.
Cosa ti serve
Strumenti
Mostra di più…
  1. Razer Basilisk V3 Switch Replacement, Skates: passo 1, immagine 1 di 1
    • Locate each of the skates.
  2. Razer Basilisk V3 Switch Replacement: passo 2, immagine 1 di 3 Razer Basilisk V3 Switch Replacement: passo 2, immagine 2 di 3 Razer Basilisk V3 Switch Replacement: passo 2, immagine 3 di 3
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Switch Replacement, Backplate: passo 3, immagine 1 di 1
    • Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Switch Replacement: passo 4, immagine 1 di 3 Razer Basilisk V3 Switch Replacement: passo 4, immagine 2 di 3 Razer Basilisk V3 Switch Replacement: passo 4, immagine 3 di 3
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Switch Replacement: passo 5, immagine 1 di 3 Razer Basilisk V3 Switch Replacement: passo 5, immagine 2 di 3 Razer Basilisk V3 Switch Replacement: passo 5, immagine 3 di 3
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
  6. Razer Basilisk V3 Switch Replacement, Scroll Wheel Assembly: passo 6, immagine 1 di 3 Razer Basilisk V3 Switch Replacement, Scroll Wheel Assembly: passo 6, immagine 2 di 3 Razer Basilisk V3 Switch Replacement, Scroll Wheel Assembly: passo 6, immagine 3 di 3
    • Use the flat end of the spudger to pop-out the scroll wheel assembly.
    • Make sure you are careful when removing the assembly since it is still connected to the device with a ribbon cable. If you pull too hard the cable could break.
  7. Razer Basilisk V3 Switch Replacement: passo 7, immagine 1 di 3 Razer Basilisk V3 Switch Replacement: passo 7, immagine 2 di 3 Razer Basilisk V3 Switch Replacement: passo 7, immagine 3 di 3
    • Pull up on the top half of the cable connector and pull the cable from the connector.
    • The connection pins on the wire face towards the scroll wheel assembly housing. When reassembling, make sure the connectors on the cable are facing the correct direction.
  8. Razer Basilisk V3 Switch Replacement, Switch: passo 8, immagine 1 di 1
    • Use the flat end of the spudger to press the two main button modules out from their mountings.
    • Apply steady pressure to just the button modules to avoid damaging the surrounding plastic.
Conclusione
Brendin Costa
Membro da: 03/18/24
402 Reputazione
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 167
Tutti i Tempi: 1,440
