Salta al contenuto principale
PowerA Enhanced Wireless Controller L and R buttons Replacement
Ayjah Montgomery
Ayjah Montgomery e 6 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
5 - 10 minuti
Moderato
Introduzione
Vai al passo 1
If you've been experiencing issues with the functionality of your L and R buttons while using your PowerA Enhanced Wireless Controller for Nintendo Switch, you're not alone. These buttons are crucial to the operation of the controller and can often become less responsive over time due to wear and tear. This guide will walk you through the necessary steps to access and replace or clean these buttons, restoring your controller to peak performance.
This repair will address common issues such as marginal response of the L and R buttons, L and R buttons sticking due to dust or residue build up and/or physical damage on the L and R buttons.
Before beginning the repair process, it's important to remove the batteries from your controller to ensure your safety during the repair and prevent any potential issues with the motherboard. Step 1 of this guide will show you how to access the battery compartment.
Cosa ti serve
Strumenti
Mostra di più…
  1. PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: passo 1, immagine 1 di 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: passo 1, immagine 2 di 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: passo 1, immagine 3 di 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 2, immagine 1 di 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 3, immagine 1 di 2 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 3, immagine 2 di 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 4, immagine 1 di 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 4, immagine 2 di 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 4, immagine 3 di 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: passo 5, immagine 1 di 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: passo 5, immagine 2 di 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: passo 5, immagine 3 di 3
    • Lift the two white latches using the iFixit opening tool.
    • Lift the white covering off.
  6. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 6, immagine 1 di 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 6, immagine 2 di 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Squeeze the buttons with rubber tweezers and push them in.
    • Grab it from the back and pull it out.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro di USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membri
11 Guide realizzate
2Commenti sulla guida
I need to know how to fix the ZR and the ZL buttons, like a faster response time
Starry Milligan - Replica
im sure this would be really helpful if i knew where i could buy the parts?
arch1e b - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 40
Tutti i Tempi: 3,704
