Salta al contenuto principale
Polaroid Automatic 100 Bottom Frame Spring Replacement
Katie Miller
Katie Miller e 4 altri collaboratori
Ultimo aggiornamento il 29 giu 2015
15 minuti
Moderato
Guida Studente in Evidenza
Introduzione
Vai al passo 1
The spring is located within a slender metal mount that is screwed into the front underside of the Polaroid. It is below the camera lens and can be seen through the mount it is within.
Cosa ti serve
Strumenti
  1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: passo 1, immagine 1 di 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: passo 1, immagine 2 di 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: passo 1, immagine 3 di 3
    • Fully extend the bellows to prevent collapse using the #1 tab.
    • Remove the camera cover in order to make the camera easier to work with.
    • When collapsing bellows, press down on the metal frame above the bellows.
  2. Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 2, immagine 1 di 1
    • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
  3. Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 3, immagine 1 di 1
    • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
  4. Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 4, immagine 1 di 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 4, immagine 2 di 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 4, immagine 3 di 3
    • Remove the spring from the shutter mount.
    • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
    • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
Conclusione
Altre 2 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Katie Miller
Membro da: 04/14/15
680 Reputazione
5 Guide realizzate
Cal Poly, Team 4-3, Maness Spring 2015 Membro di Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Membri
6 Guide realizzate
2Commenti sulla guida
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - Replica
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,193
