Salta al contenuto principale
Philips Norelco BG2040 BodyGroom 7100 Motor Replacement
August Post
August Post e un altro collaboratore
Ultimo aggiornamento il July 15, 2024
25 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show how to take out a broken motor, and replace it with a new one. You may need this if either the trimmer or shaver head on the Philips Norelco Bodygroom stop working due to motor malfunctions. It is also necessary for this guide to show how to disassemble and reassemble the trimmer in order to get to the motors. It is recommended to have the iFixit Pro Tech Toolkit since it will contain all tools necessary for this guide. Lastly, you will need to provide your own working motor to replace the broken one.
Cosa ti serve
Strumenti
Mostra di più…
  1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, LED Board: passo 1, immagine 1 di 2 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, LED Board: passo 1, immagine 2 di 2
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 2, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 2, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 2, immagine 3 di 3
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 3, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 3, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 3, immagine 3 di 3
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 4, immagine 1 di 2 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 4, immagine 2 di 2
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 5, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 5, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 5, immagine 3 di 3
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 6, immagine 1 di 2 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 6, immagine 2 di 2
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 7, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 7, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 7, immagine 3 di 3
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
  8. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: passo 8, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: passo 8, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: passo 8, immagine 3 di 3
    • *Please note that you do not need to remove the LED board from the battery pack for this guide. Begin the following steps after removal of the entire battery pack.*
    • Using the spudger, unclip the plastic housing around white casing.
    • Remove one half of the black housing first, and then proceed to the next half.
  9. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 9, immagine 1 di 1
    • Once housing is removed, pull off shaver head. *Once black housing is removed this part may fall off*
  10. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 10, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 10, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: passo 10, immagine 3 di 3
    • Use spudger to pry motor out of the white housing.
    • Pull waterproofing case off of the motor.
Conclusione
Altre 2 persone hanno completato questa guida.
August Post
Membro da: 11/07/17
415 Reputazione
3 Guide realizzate
IUPUI, Team S2-G4, Harley Fall 2017 Membro di IUPUI, Team S2-G4, Harley Fall 2017
IUPUI-HARLEY-F17S2G4
3 Membri
7 Guide realizzate
Un commento
Great guide. Thanks
Steve Riggle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,688
