Salta al contenuto principale
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
Ashley Kim
Ashley Kim e 3 altri collaboratori
Ultimo aggiornamento il December 6, 2018
8 - 10 minuti
Facile
Introduzione
Vai al passo 1
Use this guide to replace your 12 pin connector if it is damaged and does not charge properly. When replacing the component, use a Phillips #1 screwdriver and iFixit Opening Tools to proceed with the replacement.
Cosa ti serve
Strumenti
  1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: passo 1, immagine 1 di 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: passo 1, immagine 2 di 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: passo 1, immagine 3 di 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 2, immagine 1 di 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 2, immagine 2 di 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 2, immagine 3 di 3
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 3, immagine 1 di 1
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off easily.
  4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 4, immagine 1 di 1
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 5, immagine 1 di 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 5, immagine 2 di 2
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 6, immagine 1 di 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 6, immagine 2 di 2
    • Remove one 10 mm screw by using the Phillips #1 screwdriver.
    • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
  7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 7, immagine 1 di 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 7, immagine 2 di 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 7, immagine 3 di 3
    • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
    • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
Conclusione
Ashley Kim
Membro da: 10/08/18
187 Reputazione
1 Guida realizzata
Cal Poly, Team S13-G7, White Fall 2018 Membro di Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 328
