Salta al contenuto principale
Petlibro Air Automatic Pet Feeder Motor Replacement
Joseph Ambriz
Joseph Ambriz e 3 altri collaboratori
Ultimo aggiornamento il December 19, 2024
5 minuti
Moderato
Necessarie Più Immagini
Passi mancanti
Introduzione
Vai al passo 1
Has your Pet Libro Air Automatic Pet Feeder (model, PLAF008) stopped dispensing food? Let's start by cleaning the rotor it's a very common problem for food to get stuck in them. Without a clean rotor, the pet feeder won’t be able to dispense properly. It is also convenient to have a safe place to store screws while working to not lose them as they are crucial for reassembly.
Cosa ti serve
Strumenti
  1. Petlibro Air Automatic Pet Feeder Motor Replacement, Batteries: passo 1, immagine 1 di 1
    • Make sure your device is off, and no other power supply is connected.
    • Flip your device upside down.
  2. Petlibro Air Automatic Pet Feeder Motor Replacement: passo 2, immagine 1 di 1
    • Push in the black tab securing the battery compartment panel.
    • Lift up the panel.
  3. Petlibro Air Automatic Pet Feeder Motor Replacement: passo 3, immagine 1 di 1
    • Remove the discharged batteries and replace them with new 3 X D alkaline batteries.
  4. Petlibro Air Automatic Pet Feeder Motor Replacement, Power Supply: passo 4, immagine 1 di 1
    • Remove the four screws in the battery compartment.
    • Remove the batteries first
  5. Petlibro Air Automatic Pet Feeder Motor Replacement: passo 5, immagine 1 di 1
    • After unscrewing, you’ll see the machinery inside your device.
  6. Petlibro Air Automatic Pet Feeder Motor Replacement, Motor: passo 6, immagine 1 di 1
    • Disconnect the attached cables.
    • Remove the motor.
Conclusione
Un commento
Where can I buy the PetLibro motor replacement? Would this work for the Space Feeder as well? The door will not open to dispense the food so perhaps it has to do with the motor. I like to fix things so any feedback is welcomed.
RCHAT13 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 33
Tutti i Tempi: 125
