Salta al contenuto principale
Petlibro Air Automatic Pet Feeder Feeding Mechanism Replacement
Joseph Ambriz
Joseph Ambriz e 3 altri collaboratori
Ultimo aggiornamento il March 11, 2025
5 minuti
Moderato
Necessarie Più Immagini
Introduzione
Vai al passo 1
Maybe your petlibro air automatic pet feeder (model PLAF008) doesn’t want to dispense food. You filled up the tank to the required amount, but it still does not want to dispense. But then you check your feeding mechanism that dispenses food into your bowl and notice that there is some food blocked. It doesn’t mean that your feeding mechanism is broken, but instead it needs some cleaning.
  1. Petlibro Air Automatic Pet Feeder Feeding Mechanism Replacement, Feeding Mechanism: passo 1, immagine 1 di 2 Petlibro Air Automatic Pet Feeder Feeding Mechanism Replacement, Feeding Mechanism: passo 1, immagine 2 di 2
    • Flip up the latches on the sides of the device.
    • Lift the case up and off.
  2. Petlibro Air Automatic Pet Feeder Feeding Mechanism Replacement: passo 2, immagine 1 di 1
    • Twist the feeding mechanism to the right to unlock it.
  3. Petlibro Air Automatic Pet Feeder Feeding Mechanism Replacement: passo 3, immagine 1 di 1
    • Inspect the feeding mechanism and remove any jammed kibble.
    • Rotate the feeding mechanism in order to unlock the part so that you can take it off. (There should be a lock and unlock graphic on the feeding mechanism)
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 70
