Salta al contenuto principale
Pentax LX Mirror Box Removal
Sam Gustafson
Sam Gustafson e un altro collaboratore
Ultimo aggiornamento il January 31, 2025
2 - 3 ore
Molto difficile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
A guide for removing the mirror box of the Pentax LX. This is often required for general maintenance of the camera such as servicing the shutter, removing and replacing the rubber bumpers and cleaning the mirror mechanism. Previous experience with camera repair and a general knowledge of how the camera operates is highly recommended. The guide may not contain every detail and the service manual is necessary for proper adjustment and coupling of all mechanisms during reassembly. Additionally, the wiring in the LX is complex and wire colors may be hard to distinguish. When in doubt, take extra pictures so you can properly reassemble.
Any disassembly of the LX body will compromise the weather sealing. New seals must be reapplied during final reassembly to restore weather proofing.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Pentax LX Mirror Box Removal, Remove rewind knob: passo 1, immagine 1 di 2 Pentax LX Mirror Box Removal, Remove rewind knob: passo 1, immagine 2 di 2
    • Place a thin tool in the rewind fork and unscrew the topside knob.
    • Remove the washer under the rewind knob.
  2. Pentax LX Mirror Box Removal, Remove exposure compensation dial: passo 2, immagine 1 di 3 Pentax LX Mirror Box Removal, Remove exposure compensation dial: passo 2, immagine 2 di 3 Pentax LX Mirror Box Removal, Remove exposure compensation dial: passo 2, immagine 3 di 3
    • Remove three #000 5.5 mm screws.
    • Remove exposure compensation dial assembly.
    • Remove washer.
    • Remove rubber seal.
  3. Pentax LX Mirror Box Removal, Remove rewind side top cover: passo 3, immagine 1 di 2 Pentax LX Mirror Box Removal, Remove rewind side top cover: passo 3, immagine 2 di 2
    • Remove one #00 X mm screw.
    • Remove one #00 2.5 mm screw.
  4. Pentax LX Mirror Box Removal, Remove winding lever: passo 4, immagine 1 di 3 Pentax LX Mirror Box Removal, Remove winding lever: passo 4, immagine 2 di 3 Pentax LX Mirror Box Removal, Remove winding lever: passo 4, immagine 3 di 3
    • Winding lever cover is reverse threaded.
    • Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
    • Remove four #000 2.5 mm screws.
    • Use spanners to remove top cover retaining nut.
  5. Pentax LX Mirror Box Removal, Remove shutter speed dial: passo 5, immagine 1 di 3 Pentax LX Mirror Box Removal, Remove shutter speed dial: passo 5, immagine 2 di 3 Pentax LX Mirror Box Removal, Remove shutter speed dial: passo 5, immagine 3 di 3
    • Gently remove the rubber covering around the shutter speed dial.
    • Remove three #000 1.6 mm screws.
    • Remove cover ring.
    • Installation Notes: After the camera has been fully tested, use a few dabs of contact cement to fix the rubber covering back in place.
  6. Pentax LX Mirror Box Removal, Remove wind side top cover: passo 6, immagine 1 di 3 Pentax LX Mirror Box Removal, Remove wind side top cover: passo 6, immagine 2 di 3 Pentax LX Mirror Box Removal, Remove wind side top cover: passo 6, immagine 3 di 3
    • Lift off top cover.
  7. Pentax LX Mirror Box Removal, Remove bottom cover screws: passo 7, immagine 1 di 3 Pentax LX Mirror Box Removal, Remove bottom cover screws: passo 7, immagine 2 di 3 Pentax LX Mirror Box Removal, Remove bottom cover screws: passo 7, immagine 3 di 3
    • Remove the rubber bumper covering the screw.
    • Remove one #00 1.8 mm screw.
    • Repeat on the other side of the bottom plate (#00 3.0 mm screw).
  8. Pentax LX Mirror Box Removal, Remove bottom cover: passo 8, immagine 1 di 1
    • Remove one #00 3.0 mm screw.
    • Remove bottom cover.
  9. Pentax LX Mirror Box Removal, Remove front leatherette: passo 9, immagine 1 di 2 Pentax LX Mirror Box Removal, Remove front leatherette: passo 9, immagine 2 di 2
    • Use isopropyl alcohol to soften the adhesive along the edge of the leatherette.
    • Use a dull spudger or scraper to peel off the covering.
    • Turn the self timer lever to the 9 o'clock position.
    • Loosen the entire right side leatherette in the same manner, then work it over and around the self timer lever to remove.
    • Installation Notes: Use contact cement to reattach the leatherette. This should be the very last step in reassembly, after the camera has been fully tested.
  10. Pentax LX Mirror Box Removal, Remove two cover plates: passo 10, immagine 1 di 2 Pentax LX Mirror Box Removal, Remove two cover plates: passo 10, immagine 2 di 2
    • Remove the two cover plates under the leatherette.
    • They may stick to the covering adhesive and come off on their own.
    • This small plug may also be loose.
  11. Pentax LX Mirror Box Removal, Unsolder relay board: passo 11, immagine 1 di 2 Pentax LX Mirror Box Removal, Unsolder relay board: passo 11, immagine 2 di 2
    • Unsolder one gray wire.
    • Unsolder two yellow wires.
    • Unsolder one blue wire.
    • Unsolder one red wire.
  12. Pentax LX Mirror Box Removal, Remove front lens board: passo 12, immagine 1 di 3 Pentax LX Mirror Box Removal, Remove front lens board: passo 12, immagine 2 di 3 Pentax LX Mirror Box Removal, Remove front lens board: passo 12, immagine 3 di 3
    • Unscrew four #00 X mm screws.
    • Unsolder one white wire.
    • Unsolder one pink wire.
    • Unsolder one light green wire.
    • Check the mounting points for shim washers. If they are loose, note the position and remove.
    • Installation Notes: Check the function of the self timer and the depth of field preview lever after install.
  13. Pentax LX Mirror Box Removal, Remove light seal frame: passo 13, immagine 1 di 1
    • Remove four #000 1.8 mm screws.
    • Remove the light seal frame.
  14. Pentax LX Mirror Box Removal, Unsolder exp/ISO resistor: passo 14, immagine 1 di 3 Pentax LX Mirror Box Removal, Unsolder exp/ISO resistor: passo 14, immagine 2 di 3 Pentax LX Mirror Box Removal, Unsolder exp/ISO resistor: passo 14, immagine 3 di 3
    • Unsolder one purple wire.
    • Unsolder one green wire.
    • Unsolder two brown wires under the loop of flex cable.
  15. Pentax LX Mirror Box Removal, Remove exp/ISO resistor: passo 15, immagine 1 di 3 Pentax LX Mirror Box Removal, Remove exp/ISO resistor: passo 15, immagine 2 di 3 Pentax LX Mirror Box Removal, Remove exp/ISO resistor: passo 15, immagine 3 di 3
    • Unscrew three #00 3.0 mm screws.
    • Remove exp/ISO resistor assembly.
    • Remove exp. compensation coupling cam.
    • There are two loose ball bearings that sit in these holes. Do not lose.
    • Installation Note: Push this lever back to properly seat the exposure compensation lock. Check that the flag in the viewfinder is working properly. It should not be visible when dial is set to 1x and pop into view when set to any other value.
  16. Pentax LX Mirror Box Removal, Detach metering cell PCB: passo 16, immagine 1 di 1
    • Remove two #000 screws.
    • The PCB will remain attached but can move out of the way for soldering access.
  17. Pentax LX Mirror Box Removal, Unsolder adjustment PCB: passo 17, immagine 1 di 2 Pentax LX Mirror Box Removal, Unsolder adjustment PCB: passo 17, immagine 2 di 2
    • Unsolder five black wires.
    • Unsolder two green wires.
    • Unsolder one yellow wire.
    • Unsolder one orange wire.
    • Unsolder one light brown wire.
  18. Pentax LX Mirror Box Removal, Remove battery compartment: passo 18, immagine 1 di 2 Pentax LX Mirror Box Removal, Remove battery compartment: passo 18, immagine 2 di 2
    • Unscrew two #00 2.5 mm screws.
  19. Pentax LX Mirror Box Removal, Unsolder main PCB: passo 19, immagine 1 di 3 Pentax LX Mirror Box Removal, Unsolder main PCB: passo 19, immagine 2 di 3 Pentax LX Mirror Box Removal, Unsolder main PCB: passo 19, immagine 3 di 3
    • Unsolder one light blue wire (may appear beige).
    • Unsolder two black wires.
    • Unsolder one brown wire.
  20. Pentax LX Mirror Box Removal, Unsoldering: passo 20, immagine 1 di 3 Pentax LX Mirror Box Removal, Unsoldering: passo 20, immagine 2 di 3 Pentax LX Mirror Box Removal, Unsoldering: passo 20, immagine 3 di 3
    • Unsolder one light blue/teal wire.
  21. Pentax LX Mirror Box Removal, Remove condenser lens: passo 21, immagine 1 di 1
    • Remove four #00 1.8 mm screws.
    • Lift out bezel with glass attached.
  22. Pentax LX Mirror Box Removal, Lock viewfinder needle indicator: passo 22, immagine 1 di 2 Pentax LX Mirror Box Removal, Lock viewfinder needle indicator: passo 22, immagine 2 di 2
    • Turn shutter speed selector to 'Auto'.
    • Turn lock lever screw clockwise to loosen. Do not remove.
    • Lock lever screw is reverse threaded.
    • Push lock lever toward the needle indicator gear.
    • Turn lock lever screw counter-clockwise to tighten.
    • Locking the needle indicator keeps it in the proper position once the mirror box is removed.
  23. Pentax LX Mirror Box Removal, Unscrew main PCB: passo 23, immagine 1 di 3 Pentax LX Mirror Box Removal, Unscrew main PCB: passo 23, immagine 2 di 3 Pentax LX Mirror Box Removal, Unscrew main PCB: passo 23, immagine 3 di 3
    • Remove two #00 2.8 mm screws. Remove two loose spacers underneath the PCB.
    • Remove two #00 2.0 mm screws.
  24. Pentax LX Mirror Box Removal, Remove mirror box: passo 24, immagine 1 di 2 Pentax LX Mirror Box Removal, Remove mirror box: passo 24, immagine 2 di 2
    • Remove two #00 3.0 mm screws.
    • Remove one #00 5.0 mm screw.
    • Remove mirror box by lifting up then out. Pull slowly and check for snags as you remove.
  25. Pentax LX Mirror Box Removal, Installation Notes: Mirror box: passo 25, immagine 1 di 2 Pentax LX Mirror Box Removal, Installation Notes: Mirror box: passo 25, immagine 2 di 2
    • Before installing the mirror box, the shutter should be wound and the mirror released into the taking position (up against the focusing screen).
    • After mounting the mirror box, make sure all necessary wires are available through the bottom of the camera for soldering.
    • Check for proper coupling of the self timer and the shutter button release.
    • Check that the closing curtain latch sits forward of the mirror return latch.
    • Check that the FP switch lever holds the magnet lever.
    • Select one of the mechanical shutter speeds and test the function of the mirror and shutter. The camera should be capable of a complete exposure cycle at this point.
Conclusione
Sam Gustafson
Membro da: 09/01/22
7.712 Reputazione
42 Guide realizzate
9Commenti sulla guida
Hello Sam,
Very nice guide you’ve made here - do you have any advice regarding manual speeds not being able to be adjusted and faster by turning the manual speed pot (it does alter the speed but the pot runs out of adjustment before I am able to get 1 sec to be 1 - it’s around 1,5.)
I have not cleaned and lubed yet, but am thinking a lot about doing so with your comprehensive guide :)
Any advice would be much appreciated here in order to perhaps be spared of unnecessary work :)
Phil810 - Replica
My first thought is to make sure you are testing the speeds with film in the camera, although this can be a bit tricky with some testers. For the slow speeds, like 1s, the camera measures the light off the surface of the film and calculates the proper exposure in real time. Without film loaded, it measures the light off the pressure plate or whatever you testing unit puts in the film plane. These are usually "darker" than film and result in artificially long shutter times.
Sam Gustafson - Replica
Ah that could definitely be an explanation for my problem, since I was not testing with film in - will definitely have go at that and hopefully that does it - thank you very much for the help :)
Phil810 -
That was the solution to mu problem - thank you again, Sam :)
Phil810 -
Manual mode, both mechanical (>1/60th) and electronically controlled speeds (<1/60th) don't require film to be present. Electronically controlled speeds are adjusted with VRB B, only after shutter curtain speeds are correctly adjusted and the mechanical speeds are correct. If 1/2000th isn't within limits, the high-speed cam required changing. Only in auto is film required.
RC HeliHaven -
light meter won't shut off, The metering light never goes out until the battery runs out, any solutions? I've asked a few repairmen and they all say they can't fix it because it would require replacing the motherboard or circuitry, Sadly, I have this problem with both of my 2 lx
王真真 - Replica
It is correct that the meter/led's staying on can't be rectified without a replacement circuit, except in one instance where the shutter release lever tab needs adjustment.
I have half a dozen here with the same issue.
RC HeliHaven -
Great write up. Brutal camera to work on that very, very few repairers will even contemplate taking on.
Almost as bad as Canon NEW F1!
Edit:
The weather sealing for the baseplate and two top covers actually came in a tube no longer available - there were no pre-made seals.
Best alternative now is a bit of RTV silicone as is used for mould making (not bath sealant type though!)
RC HeliHaven - Replica
Thanks for the advice on the weather sealing. I've only heard of one shop being able to replace the seals but I've wanted to experiment with some "home remedies".
In your other comment you mentioned having some bodies with the always on failure. I'd like to ask you some questions about them but iFixit doesn't have direct messaging. Are you online at any other forums where I could contact you? I'm on pentaxforums, photrio, and reddit mostly.
Sam Gustafson -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 98
Tutti i Tempi: 910
