Salta al contenuto principale
Parrot FLYPAD Battery Replacement
HUY NGUYEN
HUY NGUYEN e 4 altri collaboratori
Ultimo aggiornamento il August 1, 2024
10 - 20 minuti
Moderato
Introduzione
Vai al passo 1
Bring back to life your Parrot FLYPAD with a brand new battery.
This guide will assist you to correctly dismantle the controller, so that you may easily replace the battery. To prevent any loss of screws, it is important to utilize a magnetic mat placed under the controller.
Cosa ti serve
Strumenti
Mostra di più…
  1. Parrot FLYPAD Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Use a T6 screwdriver to remove the six screws from the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Battery Replacement: passo 2, immagine 1 di 1
    • Use a screwdriver to remove the two 0.7 mm screws from the battery cover.
  3. Parrot FLYPAD Battery Replacement: passo 3, immagine 1 di 1
    • Separate the plastic cover from battery.
    • Avoid damaging the wires and gently remove the battery from the motherboard.
  4. Parrot FLYPAD Battery Replacement: passo 4, immagine 1 di 1
    • Use fingers to gently detach the battery wires from the motherboard.
  5. Parrot FLYPAD Battery Replacement: passo 5, immagine 1 di 1
    • Gently attach the wire connection from the new battery to the motherboard. Avoid touching the motherboard directly.
Conclusione
HUY NGUYEN
Membro da: 04/10/17
376 Reputazione
3 Guide realizzate
UW Tacoma, Team S3-G5, Liner Spring 2017 Membro di UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Membri
3 Guide realizzate
2Commenti sulla guida
Where did I get a new battery? Can’t find one.
Randy - Replica
Sorry where do I get a new parrot flypad battery. From Randy
Randy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,078
