Panasonic KX-E603 Stepper Motor Replacement
Introduzione
Vai al passo 1This guide will demonstrate how to replace the stepper motor on your typewriter, step-by-step.
Cosa ti serve
Strumenti
The stepper motor is located on the left when looking from the rear of the typewriter. Rotate the typewriter so that the stepper motor is facing you.
Using a P1 screwdriver, unscrew the top right and bottom right integrated #3 screws from the back of the stepper motor.
To reassemble your device, follow these instructions in reverse order using a working stepper motor.
