Salta al contenuto principale
Panasonic KX-E603 Case Replacement
Matthew Callaghan
Matthew Callaghan e 7 altri collaboratori
Ultimo aggiornamento il January 10, 2025
5 - 15 minuti
Moderato
Introduzione
Vai al passo 1
If your Panasonic KX-E603 typewriter has a damaged, cracked, or worn-out case, this guide will assist you in replacing it to restore the device’s functionality and appearance. The typewriter’s case not only protects the internal components but also ensures the durability and usability of the device.
Using the correct screwdriver ensures you won’t strip the screws, making the replacement procedure smooth and efficient. This guide provides a clear, step-by-step approach to safely remove and replace the typewriter case, ensuring a secure and proper fit for continued use.
Make sure that your typewriter is off and unplugged before you begin this repair.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Panasonic KX-E603 Case Replacement, Case: passo 1, immagine 1 di 2 Panasonic KX-E603 Case Replacement, Case: passo 1, immagine 2 di 2
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Panasonic KX-E603 Case Replacement: passo 2, immagine 1 di 1
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Panasonic KX-E603 Case Replacement: passo 3, immagine 1 di 1
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Panasonic KX-E603 Case Replacement: passo 4, immagine 1 di 2 Panasonic KX-E603 Case Replacement: passo 4, immagine 2 di 2
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Panasonic KX-E603 Case Replacement: passo 5, immagine 1 di 2 Panasonic KX-E603 Case Replacement: passo 5, immagine 2 di 2
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Panasonic KX-E603 Case Replacement: passo 6, immagine 1 di 3 Panasonic KX-E603 Case Replacement: passo 6, immagine 2 di 3 Panasonic KX-E603 Case Replacement: passo 6, immagine 3 di 3
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Panasonic KX-E603 Case Replacement: passo 7, immagine 1 di 2 Panasonic KX-E603 Case Replacement: passo 7, immagine 2 di 2
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. Panasonic KX-E603 Case Replacement: passo 8, immagine 1 di 2 Panasonic KX-E603 Case Replacement: passo 8, immagine 2 di 2
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Panasonic KX-E603 Case Replacement: passo 9, immagine 1 di 3 Panasonic KX-E603 Case Replacement: passo 9, immagine 2 di 3 Panasonic KX-E603 Case Replacement: passo 9, immagine 3 di 3
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 17-1, Forte Spring 2015 Membro di Cal Poly, Team 17-1, Forte Spring 2015
CPSU-FORTE-S15S17G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 505
