Salta al contenuto principale
Panasonic ER-GN30-K Motor Replacement
Corey Tappan
Corey Tappan e 4 altri collaboratori
Ultimo aggiornamento il July 13, 2024
15 minuti
Moderato
Introduzione
Vai al passo 1
You have tried everything to attempt to make your device work again, if nothing has succeeded the motor may need to be replaced. Follow this guide on how to remove the motor.
Cosa ti serve
Strumenti
Mostra di più…
  1. Panasonic ER-GN30-K Motor Replacement, Motor: passo 1, immagine 1 di 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: passo 2, immagine 1 di 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: passo 3, immagine 1 di 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: passo 4, immagine 1 di 1
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: passo 5, immagine 1 di 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: passo 6, immagine 1 di 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: passo 7, immagine 1 di 2 Panasonic ER-GN30-K Motor Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: passo 8, immagine 1 di 1
    • Remove the motor from the case by sliding the cover off of it.
    you are really awesome . How can I make it run on electricity
    Medo Medo - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
Corey Tappan
Membro da: 08/27/15
209 Reputazione
1 Guida realizzata
USF Tampa, Team 15-3, Blackwell Fall 2015 Membro di USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Membri
10 Guide realizzate
2 Commenti
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - Replica
Thanks for such a detailed step by step to disassemble. It appears that the motor is not functioning: LD-050FF-2043V motor. But I was not able to find a replacement on the internet. Any suggestions?
David Freedman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 56
Tutti i Tempi: 3,935
