Salta al contenuto principale
Palm Zire m150 Control Button Replacement
Kate
Kate e un altro collaboratore
Ultimo aggiornamento il 17 mag 2016
5 minuti
Facile
Inconveniente Markup
Introduzione
Vai al passo 1
This guide will teach you how to replace the control button on your Palm Zire m150. If you don't need to replace it, it will also teach you how to take the device apart in order to clean the control button.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Palm Zire m150 Control Button Replacement, Control Button: passo 1, immagine 1 di 2 Palm Zire m150 Control Button Replacement, Control Button: passo 1, immagine 2 di 2
    • Lift up the flap on the Palm Zire M150.
    • For the purpose of this guide and being able to see clearly, we removed the flap completely. You can keep your flap on if you wish.
    • If you wish to remove it, gently lift up on the flap and pull horizontally. It should come off without an issue.
  2. Palm Zire m150 Control Button Replacement: passo 2, immagine 1 di 1
    • Take the screwdriver from the IFixit toolkit and use the T6 bit. Unscrew the the top two 3mm screws above where the flap was connected to the device.
  3. Palm Zire m150 Control Button Replacement: passo 3, immagine 1 di 2 Palm Zire m150 Control Button Replacement: passo 3, immagine 2 di 2
    • Gently pull the top half and bottom half off the device apart using both hands so that it looks like the second photo.
    • You can use your finger nails to pry apart the top half and the bottom half of the device. If that doesn't work, use the opening picks from the toolkit.
  4. Palm Zire m150 Control Button Replacement: passo 4, immagine 1 di 1
    • This is the button that you are going to be replacing. Grab the grey button and pull it apart from the device.
    • If you are not replacing the button and you are just cleaning it, make sure you are gentle when you pull it from the device so that you don't break the button.
    • You can use compressed air to clean them or an alcohol wipe.
  5. Palm Zire m150 Control Button Replacement: passo 5, immagine 1 di 1
    • The button is now off of the device. If you are cleaning it, use the compressed air or the alcohol wipe.
    • If installing a new button, throw away the one you just took off and snap the new one back on the white piece.
Conclusione
1Commento della guida
Kate what hairy arms you have lol
Jimfixer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 456
