PSP 300xc LCD Replacement
Introduzione
Vai al passo 1Did you drop your PSP? If your LCD is broken for any reason, you're in luck! This guide will show you how to replace that LCD with a brand new one.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
Lift the battery out of the PSP.
Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
Remove a single Phillips screw securing the home bar to the PSP 300xc.
If you are brave enough steps 7-14 can be avoided, i literally just replaced this power switch skipping 7-14 because the ribbon cable is long and flexible enough to put in, but do not screw the power board into place while doing this makes it a lot easier.
Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
Home bar cable
Microphone cable
LCD display data cable
Touchscreen cable
After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
Altre 11 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
