Salta al contenuto principale
PSP 300x Front Casing Replacement
kbrunner
kbrunner e 16 altri collaboratori
Ultimo aggiornamento il March 24, 2025
5 minuti
Moderato
Immagini Non Adeguate
Introduzione
Vai al passo 1
Steps for replacing the outer casing of a Sony PSP-3000.
Cosa ti serve
Ricambi
Strumenti
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. PSP 300x Front Casing Replacement, Battery: passo 1, immagine 1 di 3 PSP 300x Front Casing Replacement, Battery: passo 1, immagine 2 di 3 PSP 300x Front Casing Replacement, Battery: passo 1, immagine 3 di 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Front Casing Replacement, Front Casing: passo 2, immagine 1 di 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    This will end your warranty, so do it on your own risk!
    Paweł Kasztura - Replica
    Even though warranties are long expired on these things.
    Vincent C. -
    “IF” your on this Site “I FIX IT(tm) to lean how to repair something on your own… you “Should NOT” be too concerned about warranty any longer, as if you were .. for your iPhone or Pad etc… you would have taken it to the supplier.. No??
    Barry Goian - Replica
  3. PSP 300x Front Casing Replacement: passo 3, immagine 1 di 2 PSP 300x Front Casing Replacement: passo 3, immagine 2 di 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Front Casing Replacement: passo 4, immagine 1 di 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Front Casing Replacement: passo 5, immagine 1 di 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    “DON’T” forget to put your screws separately on a mag mat (Or sticky tape) so to 1) Not loose them & 2) Remember where they go as they may be of differing sizes. (Refer time the pictures also helps, but you can take a pic on your camera as you go to remind you also.
  6. PSP 300x Front Casing Replacement: passo 6, immagine 1 di 2 PSP 300x Front Casing Replacement: passo 6, immagine 2 di 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    J’ai récemment fait cette réparation et le boîtier avant ne voulait pas venir à condition d’enlever les deux vis sur le boîtier arrière au niveau du joystick et de la croix directionnelle. Il manque donc selon moi une partie mais je peux me tromper !
    Valentin Boileau - Replica
Conclusione
Altre 28 persone hanno completato questa guida.
kbrunner
Membro da: 11/05/09
81 Reputazione
1 Guida realizzata
Cal Poly, Team 19-2, Maness Fall 2009 Membro di Cal Poly, Team 19-2, Maness Fall 2009
CPSU-MANESS-F09S19G2
3 Membri
12 Guide realizzate
1Commento della guida
This is only the faceplate, not a casing replacement, come on
Dick - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 67
Ultimi 30 Giorni: 306
Tutti i Tempi: 19,892
