Salta al contenuto principale
PSP 2000 Front Casing Replacement
pepe32290
pepe32290 e 10 altri collaboratori
Ultimo aggiornamento il 15 mar 2024
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
Paint job scratched? Going custom? Change out your faceplate assembly!
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. PSP 2000 Front Casing Replacement, Battery: passo 1, immagine 1 di 3 PSP 2000 Front Casing Replacement, Battery: passo 1, immagine 2 di 3 PSP 2000 Front Casing Replacement, Battery: passo 1, immagine 3 di 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Front Casing Replacement, Front Casing: passo 2, immagine 1 di 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Front Casing Replacement: passo 3, immagine 1 di 2 PSP 2000 Front Casing Replacement: passo 3, immagine 2 di 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Front Casing Replacement: passo 4, immagine 1 di 2 PSP 2000 Front Casing Replacement: passo 4, immagine 2 di 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Beware that some models of PSP 2000 (mine is a limited edition Crisis Core FF7 silver version, so I suppose it is related to it being a japanese PSP) have 2 minute TORX screws (T1? T2?) instead of the 2x 4mm Phillips pointed in orange around the USB port.
    Mighty Sashiman - Replica
  5. PSP 2000 Front Casing Replacement: passo 5, immagine 1 di 2 PSP 2000 Front Casing Replacement: passo 5, immagine 2 di 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
Conclusione
Altre 17 persone hanno completato questa guida.
pepe32290
Membro da: 10/19/09
1.687 Reputazione
4 Guide realizzate
Cal Poly, Team 6-3, Maness Fall 2009 Membro di Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Membri
37 Guide realizzate
1Commento della guida
Does the front casing also have the plastic glass screen on it as well? Or is that separate?
Arthur - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 207
Tutti i Tempi: 29,006
