Salta al contenuto principale
PSP 2000 Display Replacement
espinks
espinks e 10 altri collaboratori
Ultimo aggiornamento il 28 giu 2025
5 - 15 minuti
Moderato
Guida In Evidenza
Guida Studente in Evidenza
  1. PSP 2000 Display Replacement, Battery: passo 1, immagine 1 di 3 PSP 2000 Display Replacement, Battery: passo 1, immagine 2 di 3 PSP 2000 Display Replacement, Battery: passo 1, immagine 3 di 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Display Replacement, Front Casing: passo 2, immagine 1 di 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Display Replacement: passo 3, immagine 1 di 2 PSP 2000 Display Replacement: passo 3, immagine 2 di 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Display Replacement: passo 4, immagine 1 di 2 PSP 2000 Display Replacement: passo 4, immagine 2 di 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Beware that some models of PSP 2000 (mine is a limited edition Crisis Core FF7 silver version, so I suppose it is related to it being a japanese PSP) have 2 minute TORX screws (T1? T2?) instead of the 2x 4mm Phillips pointed in orange around the USB port.
    Mighty Sashiman - Replica
  5. PSP 2000 Display Replacement: passo 5, immagine 1 di 2 PSP 2000 Display Replacement: passo 5, immagine 2 di 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
  6. PSP 2000 Display Replacement, Display: passo 6, immagine 1 di 3 PSP 2000 Display Replacement, Display: passo 6, immagine 2 di 3 PSP 2000 Display Replacement, Display: passo 6, immagine 3 di 3
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
    Theres a latch you have to pry on the other side of the console through the small hole in order to remove home menu bar
    Janus Golovka - Replica
  7. PSP 2000 Display Replacement: passo 7, immagine 1 di 3 PSP 2000 Display Replacement: passo 7, immagine 2 di 3 PSP 2000 Display Replacement: passo 7, immagine 3 di 3
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
    There are 2 ribbons connected to the screen. Both of them have to be disconnected in order to remove the screen.
    Ovismue Veholkin - Replica
    Do not lift the black tab on the thin cable. That's attached to the logic board.
    Colin Wack - Replica
Conclusione
Altre 63 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
espinks
Membro da: 10/18/09
3.713 Reputazione
5 Guide realizzate
Cal Poly, Team 6-3, Maness Fall 2009 Membro di Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Membri
44 Guide realizzate
6Commenti sulla guida
That does’t seem that hard. Is this tutorial working with the PSP2004?
Jack Galinski - Replica
Yes it is, just did it :)
Billy -
Thanks for the great tut just fixed a trash find psp with a cracked lcd.
myhero667 - Replica
Parfait tutoriel pour remplacer mon écran de PSP 2004. Un grand merci
Ramius59 - Replica
I was wondering why after replacing the screen that the new one only shows a blank black screen. The backlight turns on and it plays the boot up sequence and you can play around on the Home Screen, but you just cant see what you’re doing on the screen. Everything seems connected right. Any suggestions??
Dylan Thomas - Replica
Same here after changing the screen
Hdgssjjddk -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 32
Ultimi 7 Giorni: 193
Ultimi 30 Giorni: 866
Tutti i Tempi: 74,668
