Salta al contenuto principale
Onkyo C-7030 Laser Module Replacement
Lami
Lami e un altro collaboratore
Ultimo aggiornamento il 26 giu 2024
1 ora
Moderato
Inconveniente Markup
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This guide shows the steps used to replace the laser module in the CD player. New units can be sourced on the Internet for under 50 Euro. I decided to write this after searching in vain for specific instructions or videos on how to change the laser for this model. It isn't obvious how to do this when one first opens the upper case, because the laser module is encased in a plastic housing which doesn't allow easy access to the laser.
Cosa ti serve
Strumenti
  1. Onkyo C-7030 Laser Module Replacement, Remove the top case: passo 1, immagine 1 di 3 Onkyo C-7030 Laser Module Replacement, Remove the top case: passo 1, immagine 2 di 3 Onkyo C-7030 Laser Module Replacement, Remove the top case: passo 1, immagine 3 di 3
    • To remove the top case, there are 4 Phillips screws on the top back of the case, and 2 screws on each side. Pull off the case toward the rear of the unit.
  2. Onkyo C-7030 Laser Module Replacement, Eject the CD Drawer: passo 2, immagine 1 di 2 Onkyo C-7030 Laser Module Replacement, Eject the CD Drawer: passo 2, immagine 2 di 2
    • This step can also be done as the first step. Plug in the CD player and push the eject button. Pop off the front bezel. Then unplug the CD player again. While the unit is plugged in do not look into the laser, although it is very protected in this CD model and relatively difficult to do.
  3. Onkyo C-7030 Laser Module Replacement, Remove the Laser Modul Housing -  1: passo 3, immagine 1 di 3 Onkyo C-7030 Laser Module Replacement, Remove the Laser Modul Housing -  1: passo 3, immagine 2 di 3 Onkyo C-7030 Laser Module Replacement, Remove the Laser Modul Housing -  1: passo 3, immagine 3 di 3
    • Carefully turn the CD player over so the bottom side is up. Remove the 4 Phillips head screws that hold the housing to the base plate (photo on left).
    • Now, turn the unit back on its feet. Looking from the front of the player, there is a ribbon cable held to the side of the housing with a cable tie (see red arrow). This should be cut off with scissors. Replacement of this tie is not needed on reassembly (center photo).
    • On the right side of the housing, lift the ribbon cable and the wires from the connector near the front of the housing out of the white cable guide mounted on the base plate (green circle). It isn't necessary to remove the connectors (photo on right).
  4. Onkyo C-7030 Laser Module Replacement, Remove Laser Housing - 2: passo 4, immagine 1 di 1
    • Remove the wide ribbon cable from the rear of the laser module (red oval). Pull the ribbon straight out, gently but firmly, holding it on the blue coloured zone near the connector.
  5. Onkyo C-7030 Laser Module Replacement, Remove Laser Housing - 3: passo 5, immagine 1 di 1
    • Now the housing can be removed. I left the cable connectors on the right side of the housing connected, as they are long enough to leave them attached. It is necessary to partially close the CD tray, then carefully move the entire housing back, guiding the CD tray through the opening in the front panel.
    • This shows the housing immediately after removal, you can see the tray has been partially closed in order to remove it from the CD player case. At this point, the connectors on the housing and on the laser module are still attached. Only the wide ribbon cable from the rear of laser module in the housing has been removed.
  6. Onkyo C-7030 Laser Module Replacement, Removal of Laser Module from Case: passo 6, immagine 1 di 2 Onkyo C-7030 Laser Module Replacement, Removal of Laser Module from Case: passo 6, immagine 2 di 2
    • Now turn the housing over to expose the laser module plate. With the housing connectors attached I rested the unit on the edge of the CD player case to work on it. There is now easy access to remove the connector on the laser module (yellow rectangle by taking a spudger and lifting first one end then the other end until the connector pops free.
    • There are four spring-mounted screws (Phillips head), as marked on the photo on the left. Remove the screws, then the springs underneath, noting the direction of the cone taper of the springs for reassembly. The laser module can now be lifted up and removed from the housing.
    • Below the springs are rubber gaskets (indicated by arrows in the right-hand photo). These must be removed and transferred to the new laser module. Remember to insert them in the holes of the new unit in the same way as they are on the old module.
  7. Onkyo C-7030 Laser Module Replacement, Preparing the New Laser Module: passo 7, immagine 1 di 3 Onkyo C-7030 Laser Module Replacement, Preparing the New Laser Module: passo 7, immagine 2 di 3 Onkyo C-7030 Laser Module Replacement, Preparing the New Laser Module: passo 7, immagine 3 di 3
    • Before inserting your new module back in the housing, a blob of sauter that is used to protect the module during transport must be removed. Photo 1 shows this blob, in the yellow rectangle, marked red by the nice fellow who sold me the new laser so I would easily recognise it easily. Without removing this, the CD player will not function.
    • Heat the blob with a sautering iron and either flick it off or suck it up with a "sauter sucker" when it liquifies. After that the contact should look similar to photo 2.
    • To reassemble after preparing the new laser module, follow the instructions in reverse order.
Conclusione
Altre 3 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Lami
Membro da: 03/08/10
473 Reputazione
2 Guide realizzate
21Commenti sulla guida
thank you very much for your post.
aabman - Replica
However, is it easy to insert the ribbon cable to the chase/laser head again? thanks.
aabman - Replica
It seems there is no "lock" for the flat cable. thx
aabman - Replica
Hi aabman, I was also a bit nervous about re-inserting the cable again, but it actually was easy to put back it. I had to take the unit out again because after the first time I reassembled everything the unit was making a bit of noise - I think that I had not tightened the four screws with the conical springs enough the first time. So I actually had the cable off twice. The blue part of the cable near where it inserts is a bit stiffer so you can get hold of it better there.
Lami - Replica
Hi Lami. Interesting that you say had a noise and put it down to the springs. After replacing the module in my girlfriend Onkyo I got a noise too. Not only that, although I was no longer getting 'no disc' on the display, it wasn't reading the disc 100% properly and wouldn't play. Then I noticed if I tilted the player at 45 degrees the noise went away and discs loaded 100% and played. Weird! Anyway I figured it must be something to with the the way the module is suspended on springs and started examining it closely. After removing the springs again what I noticed was that the springs are in pairs - a stiffer pair and lighter more 'squashy' pair. I took a guess that the stiffer pair should go at the heavier end of the module where the motors are and the lighter pair at the other end and that seems to have fixed it. No more noise and discs load properly. Cheers
FiloB -
No, there is no lock, just push it in as far as it will go...
Lami - Replica
Dear Lami, many thanks for your information. My C7030 played well but occasionally skip for 1 second etc., say around 20 - 30 minutes. Not sure if the problem casued by dated laser head or the moving mechanism. I am thinking to get a tray set only with US$10 from China. According to your quoted steps, only the ribbon cable connection will be the main stuff. I placed herewith my heartly thanks for your prompt reply. Thanks a lot!!
aabman - Replica
Accutaly, I use my C7030 as transport most the time and it sounds pretty good as a mid range transport! Thanks for your help.
aabman - Replica
Sorry, one more question pls : What is the pin number of the flat cable connector? 16PINS? Thx
aabman - Replica
Can anyone explain how to change the belt which opens/closes the tray?
ericwithakay - Replica
Hi, guys! What happened that made you change the laser module? I've got some difficulty in reading discs. No improvement after cleaning the lens. Maybe it's time for a change?? Thanks.
Carl Anderson - Replica
Hi Carl, sorry for the late answer... it was exactly that, I would put a disc in and it would churn for a while and then say "no disc" or it would show 99 on the display. Also, sometimes while playing a disc it would just kind of do the same sort of "skipping" repetitions, kind of like one used to get on a vinyl LP. I tried cleaning the disc (which sometimes helped) and using one of those laser head cleaners that you put in like a normal CD. In the end, I just decided to try the head replacement, as the other option was to throw the Onkyo away. In fact I tried to replace it with a new Yamaha, but we just didn't like the sound or the controls on the new unit, and the remote never worked correctly with the rest of the system (also Onkyo). Luckily, I hadn't thrown the Onkyo CD out ( I still had the idea of trying to fix it) and even though I couldn't find an iFixit guide for it, I tried anyway - and make my first guide as well! The CD has worked perfectly ever since.
Lami - Replica
Is there a way of cleaning the lens without removing the whole plastic housing encasing the laser module?
Daniel Lozada - Replica
Hi Daniel, for just cleaning the lens, I always have just used one of those commercial products that consists of a CD, with a tiny brush mounted on it that you insert like a normal CD, and which theoretically should clean the lens. It does seem to work.
Lami -
Thanks. I have one of those. It keeps skipping while playing. But it's sitting on top of my receiver and I'm wondering if it's the vibration. I'm going to try with stabilizers before deciding to replace the laser module.
I was able to replace the optical reader for this unit using this detailed guide. It's still skipping (I probably should've bought the whole module). And it stops playing after two or three tracks, but I guess that must be related to the way I put everything back. Thanks for the guide!
Hi Daniel, I am sorry to hear that you still have a problem. I wonder if it could be something like described by FiloB above, although if it does play 2 or 3 tracks and you don't hear any funny noises, maybe that is unlikely. You are probably correct about needing to replace the entire module. At least now that you have been through it once, it shouldn't be as bad the second time...
Lami - Replica
Final update. It was definitely the handle. I ordered one from China (gotta love those guys😂) for less than $20.00 and it finally stopped skipping. I did have to replace optical head I had buy (I think I had to do the heating off part of the instructions and it was faster to just replace the optical head). I couldn't have done it without your instructions. I really wanted to thank you again.
Hey Daniel, I am really glad that you did it! When I had the problem, I had searched around, but couldn't find much help for our model, so in the end I just decided to try to fix it and document everything with photographs to make a ifixit guide. I have had such great use of this site for years (fixed my Mac laptops I don't know how many times, with the help of the guides) and I figured I owed them. Glad it has been of use!
Lami - Replica
thanks a lot, especially the step 7 was written nowhere in the module I bought
Sergio Bruz - Replica
Really glad it was helpful. I know very well the uncertainty when doing a repair on something one isn't familiar with - and with occasional disastrous consequences. ! But far more noble to attempt a fix :-)
Lami - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 81
Tutti i Tempi: 1,876
