Salta al contenuto principale
OnePlus 8 Rear Glass Replacement
Cosa ti serve
  1. OnePlus 8 Rear Glass Replacement, Heat the rear glass: passo 1, immagine 1 di 1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
  2. OnePlus 8 Rear Glass Replacement, Insert an opening pick: passo 2, immagine 1 di 3 OnePlus 8 Rear Glass Replacement, Insert an opening pick: passo 2, immagine 2 di 3 OnePlus 8 Rear Glass Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
  3. OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: passo 3, immagine 1 di 3 OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: passo 3, immagine 2 di 3 OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: passo 3, immagine 3 di 3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
  4. OnePlus 8 Rear Glass Replacement: passo 4, immagine 1 di 3 OnePlus 8 Rear Glass Replacement: passo 4, immagine 2 di 3 OnePlus 8 Rear Glass Replacement: passo 4, immagine 3 di 3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  5. OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: passo 5, immagine 1 di 3 OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: passo 5, immagine 2 di 3 OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: passo 5, immagine 3 di 3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: passo 6, immagine 1 di 3 OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: passo 6, immagine 2 di 3 OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: passo 6, immagine 3 di 3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: passo 7, immagine 1 di 3 OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: passo 7, immagine 2 di 3 OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: passo 7, immagine 3 di 3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
  8. OnePlus 8 Rear Glass Replacement, Remove the rear glass: passo 8, immagine 1 di 3 OnePlus 8 Rear Glass Replacement, Remove the rear glass: passo 8, immagine 2 di 3 OnePlus 8 Rear Glass Replacement, Remove the rear glass: passo 8, immagine 3 di 3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
iFixit Membro di iFixit
Staff
140 Membri
18.074 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 122
Tutti i Tempi: 1,815
