Salta al contenuto principale
Olympic Fencing Foil Handguard Replacement
Chuwei Yuan
Chuwei Yuan e 3 altri collaboratori
Ultimo aggiornamento il December 11, 2024
5 minuti
Moderato
Guida Studente in Evidenza
Introduzione
Vai al passo 1
Use this guide to replace worn out handguards on Olympic-style fencing foils. All handguard parts are standardized for fencing; in this case, the old guard is being replaced with a Leon Paul handguard.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Olympic Fencing Foil Handguard Replacement, Olympic Fencing Foil Handguard: passo 1, immagine 1 di 3 Olympic Fencing Foil Handguard Replacement, Olympic Fencing Foil Handguard: passo 1, immagine 2 di 3 Olympic Fencing Foil Handguard Replacement, Olympic Fencing Foil Handguard: passo 1, immagine 3 di 3
    • Remove the nut securing the handle with the 1 x 6 mm hex key.
  2. Olympic Fencing Foil Handguard Replacement: passo 2, immagine 1 di 2 Olympic Fencing Foil Handguard Replacement: passo 2, immagine 2 di 2
    • Remove the grip and pad.
  3. Olympic Fencing Foil Handguard Replacement: passo 3, immagine 1 di 2 Olympic Fencing Foil Handguard Replacement: passo 3, immagine 2 di 2
    • Use pliers to hold the hexnut still while using a flathead screwdriver to loosen the socket holding the wire.
    • Do not completely remove the socket from the socket holder.
  4. Olympic Fencing Foil Handguard Replacement: passo 4, immagine 1 di 3 Olympic Fencing Foil Handguard Replacement: passo 4, immagine 2 di 3 Olympic Fencing Foil Handguard Replacement: passo 4, immagine 3 di 3
    • Unwrap the wire from the socket.
    • Be gentle unwrapping the wire; excessive twisting may snap the wire.
  5. Olympic Fencing Foil Handguard Replacement: passo 5, immagine 1 di 3 Olympic Fencing Foil Handguard Replacement: passo 5, immagine 2 di 3 Olympic Fencing Foil Handguard Replacement: passo 5, immagine 3 di 3
    • Take the wire out under the socket holder's hole.
    • If there is tape holding down the wire, remove it.
  6. Olympic Fencing Foil Handguard Replacement: passo 6, immagine 1 di 3 Olympic Fencing Foil Handguard Replacement: passo 6, immagine 2 di 3 Olympic Fencing Foil Handguard Replacement: passo 6, immagine 3 di 3
    • Remove the socket holder.
    • Remove the old handguard.
    • Get your new handguard ready.
  7. Olympic Fencing Foil Handguard Replacement: passo 7, immagine 1 di 2 Olympic Fencing Foil Handguard Replacement: passo 7, immagine 2 di 2
    • Thread the wire through the new handguard.
    • Insert the new handguard on the foil.
  8. Olympic Fencing Foil Handguard Replacement: passo 8, immagine 1 di 3 Olympic Fencing Foil Handguard Replacement: passo 8, immagine 2 di 3 Olympic Fencing Foil Handguard Replacement: passo 8, immagine 3 di 3
    • Thread the wire through the large sockey holder hole.
    • Insert the sockey holder back onto the foil.
    • Thread the wire through and under the small hole of the socket holder, right next to the sockets.
  9. Olympic Fencing Foil Handguard Replacement: passo 9, immagine 1 di 3 Olympic Fencing Foil Handguard Replacement: passo 9, immagine 2 di 3 Olympic Fencing Foil Handguard Replacement: passo 9, immagine 3 di 3
    • Wrap the exposed part of the wire around the socket.
    • Using a plier to hold the hexnut, use a flathead screwdriver to tighten the socket.
  10. Olympic Fencing Foil Handguard Replacement: passo 10, immagine 1 di 2 Olympic Fencing Foil Handguard Replacement: passo 10, immagine 2 di 2
    • Insert the pad.
    • Insert the grip.
    • When inserting the grip, make sure that the grip is not crushing the wire.
  11. Olympic Fencing Foil Handguard Replacement: passo 11, immagine 1 di 3 Olympic Fencing Foil Handguard Replacement: passo 11, immagine 2 di 3 Olympic Fencing Foil Handguard Replacement: passo 11, immagine 3 di 3
    • Insert and tighten the hexnut.
  12. Olympic Fencing Foil Handguard Replacement: passo 12, immagine 1 di 1
    • Make sure that the foil does not feel loose.
Linea Traguardo
Chuwei Yuan
Membro da: 10/10/24
205 Reputazione
1 Guida realizzata
UC Davis, Team 1-1, Morris Fall 2024 Membro di UC Davis, Team 1-1, Morris Fall 2024
UCD-MORRIS-F24S1G1
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 47
