Salta al contenuto principale
Nothing Phone (1) Loudspeaker Replacement
Cosa ti serve
  1. Nothing Phone (1) Loudspeaker Replacement, Heat the rear glass: passo 1, immagine 1 di 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nothing Phone (1) Loudspeaker Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • If you're having trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nothing Phone (1) Loudspeaker Replacement, Slice the adhesive: passo 3, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Slice the adhesive: passo 3, immagine 2 di 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nothing Phone (1) Loudspeaker Replacement, Slice the adhesive: passo 4, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Slice the adhesive: passo 4, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Slice the adhesive: passo 4, immagine 3 di 3
    • When you slice near the glyph, insert only the tip of the opening pick (~2-3 mm) to avoid damaging the LEDs.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nothing Phone (1) Loudspeaker Replacement: passo 5, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement: passo 5, immagine 2 di 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nothing Phone (1) Loudspeaker Replacement: passo 6, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement: passo 6, immagine 2 di 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • At this point, the rear glass should be separated from the frame. If there's still resistance around the edges of the glass, use an opening pick to separate any remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  7. Nothing Phone (1) Loudspeaker Replacement, Remove the rear glass: passo 7, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Remove the rear glass: passo 7, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Dust Blower
    $5.99
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Since the rear glass of the Nothing Phone (1) is transparent a dust blower may come in handy for cleaning before installing a new rear glass.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    Chiedi a FixBot
    Aggiungi Commento
  8. Nothing Phone (1) Loudspeaker Replacement, Remove the plastic cover: passo 8, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the plastic cover: passo 8, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the plastic cover: passo 8, immagine 3 di 3
    • The plastic covering the earpiece speaker is held in place by mild adhesive. If you're having a hard time removing it, apply a heated iOpener for 1-2 minutes to loosen the adhesive underneath.
    • Insert an opening pick underneath the grey plastic cover at the top edge of your phone.
    • Use your opening pick to pry up the plastic cover.
    • Remove the plastic cover.
    Chiedi a FixBot
    Aggiungi Commento
  9. Nothing Phone (1) Loudspeaker Replacement, Unfasten the earpiece speaker screws: passo 9, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the earpiece speaker.
    Chiedi a FixBot
    Aggiungi Commento
  10. Nothing Phone (1) Loudspeaker Replacement, Remove the earpiece speaker: passo 10, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the earpiece speaker: passo 10, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the earpiece speaker: passo 10, immagine 3 di 3
    • Insert the flat end of a spudger underneath the bottom edge of the earpiece speaker.
    • Use your spudger to pry up the earpiece speaker.
    • Use a pair of tweezers or your fingers to remove the earpiece speaker.
    Chiedi a FixBot
    Aggiungi Commento
  11. Nothing Phone (1) Loudspeaker Replacement, Disconnect the flash assembly LED glyph cables: passo 11, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Disconnect the flash assembly LED glyph cables: passo 11, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Disconnect the flash assembly LED glyph cables: passo 11, immagine 3 di 3
    • Use a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
    • Use a spudger to disconnect the LED glyph cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  12. Nothing Phone (1) Loudspeaker Replacement, Remove the recording indicator light cover: passo 12, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the recording indicator light cover: passo 12, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the recording indicator light cover: passo 12, immagine 3 di 3
    • Insert an opening pick underneath the recording indicator light cover at the top right corner of the screen.
    • Use a pair of tweezers or your fingers to remove the recording indicator light cover.
    Chiedi a FixBot
    Aggiungi Commento
  13. Nothing Phone (1) Loudspeaker Replacement, Remove the bottom LED glyph assembly: passo 13, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the bottom LED glyph assembly: passo 13, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the bottom LED glyph assembly: passo 13, immagine 3 di 3
    • Be very careful when working on the bottom LED assembly. There's a cable running underneath its whole surface that can be damaged easily.
    • The bottom LED assembly is held in place by small pieces of adhesive.
    • Slide an opening pick underneath the right, bottom and left edge of the bottom LED assembly to carefully separate it from the daughterboard cover.
    • Do not slide the opening pick deeper than shown in the photos. Otherwise you risk damaging the LED cable.
    Chiedi a FixBot
    Aggiungi Commento
  14. Nothing Phone (1) Loudspeaker Replacement, Fold over the bottom LED assembly: passo 14, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Fold over the bottom LED assembly: passo 14, immagine 2 di 2
    • The bottom LED assembly is still held in place by a small piece of adhesive sitting between the cable winds. Avoid straining or tearing the cable when folding the assembly over.
    • Use a pair of blunt nosed tweezers and carefully fold the bottom LED assembly over to get free access to the LED cable connector.
    Chiedi a FixBot
    Aggiungi Commento
  15. Nothing Phone (1) Loudspeaker Replacement, Open the connector bracket: passo 15, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Open the connector bracket: passo 15, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Open the connector bracket: passo 15, immagine 3 di 3
    • The LED connector bracket sits very tight and may require some force to open it.
    • Insert one arm of a pair of tweezers into the gap at the right side of the connector bracket.
    • Push your tweezers toward the left edge of the phone to free the closure flap of the connector bracket.
    • If you're struggling to free the flap, pull the black rubber piece to the left to give the bracket more room.
    • Lift the connector bracket with your tweezers to access the LED connector.
    Chiedi a FixBot
    Aggiungi Commento
  16. Nothing Phone (1) Loudspeaker Replacement, Disconnect the LED cable: passo 16, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Disconnect the LED cable: passo 16, immagine 2 di 2
    • Use a spudger to disconnect the LED cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  17. Nothing Phone (1) Loudspeaker Replacement, Remove the bottom LED assembly: passo 17, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Remove the bottom LED assembly: passo 17, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the bottom LED assembly.
    Chiedi a FixBot
    Aggiungi Commento
  18. Nothing Phone (1) Loudspeaker Replacement, Unfasten the daughterboard cover screws: passo 18, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the five 4.2 mm-long screws securing the daughterboard cover.
    • The center-most screw is covered by a white sticker.
    Chiedi a FixBot
    Aggiungi Commento
  19. Nothing Phone (1) Loudspeaker Replacement, Remove the plastic shield: passo 19, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Remove the plastic shield: passo 19, immagine 2 di 2
    • The grey plastic shield on top of the daughterboard cover is held in place by mild adhesive.
    • Use a pair of tweezers to carefully separate the grey plastic shield from the daughterboard cover and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  20. Nothing Phone (1) Loudspeaker Replacement, Fingerprint cable information: passo 20, immagine 1 di 1
    • When prying up the daughterboard cover in the following step be very careful and avoid levering with too much force or to press your prying tool too deep underneath the cover. Otherwise, the fingerprint cable running underneath can be easily torn.
    Chiedi a FixBot
    Aggiungi Commento
  21. Nothing Phone (1) Loudspeaker Replacement, Pry up the daughterboard cover: passo 21, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Pry up the daughterboard cover: passo 21, immagine 2 di 2
    • Insert the pointed end of a spudger underneath the top edge of the daughterboard cover just above the black rubber guard securing the LED connector bracket.
    • Pry up with the spudger to release the daughterboard cover from its clips.
    Chiedi a FixBot
    Aggiungi Commento
  22. Nothing Phone (1) Loudspeaker Replacement, Remove the daughterboard cover: passo 22, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Remove the daughterboard cover: passo 22, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the daughterboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  23. Nothing Phone (1) Loudspeaker Replacement, Remove the black rubber guard: passo 23, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Remove the black rubber guard: passo 23, immagine 2 di 2
    • Use a pair of tweezers to remove the black rubber guard securing the LED connector bracket.
    Chiedi a FixBot
    Aggiungi Commento
  24. Nothing Phone (1) Loudspeaker Replacement, Remove the connector bracket: passo 24, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Remove the connector bracket: passo 24, immagine 2 di 2
    • Use a pair of tweezers to remove the LED connector bracket.
    Chiedi a FixBot
    Aggiungi Commento
  25. Nothing Phone (1) Loudspeaker Replacement, Disconnect the interconnect cable: passo 25, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Disconnect the interconnect cable: passo 25, immagine 2 di 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  26. Nothing Phone (1) Loudspeaker Replacement, Separate the interconnect cable adhesive: passo 26, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Separate the interconnect cable adhesive: passo 26, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Separate the interconnect cable adhesive: passo 26, immagine 3 di 3
    • The interconnect cable is held in place by mild adhesive.
    • Carefully slide an opening pick underneath the interconnect cable to separate it from the charging coil assembly and the loudspeaker.
    Chiedi a FixBot
    Aggiungi Commento
  27. Nothing Phone (1) Loudspeaker Replacement, Fold over the interconnect cable: passo 27, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Fold over the interconnect cable: passo 27, immagine 2 di 2
    • During the following step do not fold the cable sharply and only bend it to avoid cable damage.
    • Use a pair of tweezers to fold the interconnect cable to the left like you'd open the cover of a book.
    Chiedi a FixBot
    Aggiungi Commento
  28. Nothing Phone (1) Loudspeaker Replacement, Unfasten the motherboard cover screws: passo 28, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the four 4.2 mm-long screws securing the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  29. Nothing Phone (1) Loudspeaker Replacement, Separate the wireless charging coil adhesive: passo 29, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Separate the wireless charging coil adhesive: passo 29, immagine 2 di 2
    • The charging coil assembly is held in place by mild adhesive.
    • Insert an opening pick underneath the bottom right edge of the charging coil assembly.
    • Slide the opening along the right edge of the charging coil assembly to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  30. Nothing Phone (1) Loudspeaker Replacement: passo 30, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement: passo 30, immagine 2 di 2
    • Insert an opening pick underneath the bottom left edge of the charging coil assembly.
    • Slide the opening along the left edge of the charging coil assembly to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  31. Nothing Phone (1) Loudspeaker Replacement, Fold over the charging board assembly: passo 31, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Fold over the charging board assembly: passo 31, immagine 2 di 2
    • When folding the charging coil assembly over avoid straining components and cables.
    • Carefully fold the charging coil to the top edge of the phone to access the motherboard cover screws.
    Chiedi a FixBot
    Aggiungi Commento
  32. Nothing Phone (1) Loudspeaker Replacement, Unfasten the motherboard cover screws: passo 32, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three 4.2 mm-long screws securing the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  33. Nothing Phone (1) Loudspeaker Replacement, Separate the camera cover and flash assembly: passo 33, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Separate the camera cover and flash assembly: passo 33, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Separate the camera cover and flash assembly: passo 33, immagine 3 di 3
    • Return the charging coil to its original position.
    • Don't try to remove the camera cover and flash assembly all the way. Its cable runs underneath the motherboard cover and is very fragile.
    • Carefully slide an opening pick underneath the camera cover and flash assembly to separate it from the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  34. Nothing Phone (1) Loudspeaker Replacement, Fold over the camera cover and flash assembly: passo 34, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Fold over the camera cover and flash assembly: passo 34, immagine 2 di 2
    • Avoid straining the camera cover and flash assembly cable when folding it over.
    • Use a pair of tweezers to carefully fold the camera cover and flash assembly toward the battery.
    Chiedi a FixBot
    Aggiungi Commento
  35. Nothing Phone (1) Loudspeaker Replacement, Unfasten the motherboard cover screws: passo 35, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the motherboard cover.
    • Return the camera cover and flash assembly to its original position.
    Chiedi a FixBot
    Aggiungi Commento
  36. Nothing Phone (1) Loudspeaker Replacement, Pry up the motherboard cover: passo 36, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Pry up the motherboard cover: passo 36, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Pry up the motherboard cover: passo 36, immagine 3 di 3
    • Carefully fold the charging coil to the top edge of the phone to access the bottom edge of the motherboard cover.
    • Insert the flat end of a spudger underneath the bottom right edge of the motherboard cover.
    • Pry up with the spudger to release the motherboard cover from its clips.
    • Repeat the prying procedure for the bottom left edge of the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  37. Nothing Phone (1) Loudspeaker Replacement, Remove the LED glyph assembly: passo 37, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the LED glyph assembly: passo 37, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the LED glyph assembly: passo 37, immagine 3 di 3
    • Remove the LED glyph assembly.
    Chiedi a FixBot
    Aggiungi Commento
  38. Nothing Phone (1) Loudspeaker Replacement, Disconnect the battery cable: passo 38, immagine 1 di 2 Nothing Phone (1) Loudspeaker Replacement, Disconnect the battery cable: passo 38, immagine 2 di 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  39. Nothing Phone (1) Loudspeaker Replacement, Unfasten the loudspeaker screws: passo 39, immagine 1 di 1
    • Remove the two screws securing the loudspeaker:
    • One 4.2 mm-long Phillips screw
    • One 4.2 mm-long Torx T5 screw
    Chiedi a FixBot
    Aggiungi Commento
  40. Nothing Phone (1) Loudspeaker Replacement, Remove the loudspeaker: passo 40, immagine 1 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the loudspeaker: passo 40, immagine 2 di 3 Nothing Phone (1) Loudspeaker Replacement, Remove the loudspeaker: passo 40, immagine 3 di 3
    • Insert an spudger underneath the top edge of the loudspeaker.
    • Use your spudger to pry up the loudspeaker.
    • Use your fingers or a pair of tweezers to remove the loudspeaker.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
iFixit Membro di iFixit
Staff
122 Membri
25.842 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 32
Ultimi 30 giorni: 118
Tutti i Tempi: 2,356
