Salta al contenuto principale
Nishiki Aero II Front Inner Tube Replacement
Tobias Elder
Tobias Elder e 6 altri collaboratori
Ultimo aggiornamento il December 15, 2023
10 - 20 minuti
Facile
Necessarie Immagini Migliori
Passi mancanti
Introduzione
Vai al passo 1
Sometimes, your tire's inner tube just goes flat. To fix that, you either buy a new one or patch the faulty one. Either way, you'll have to get the tube out of the tire, and this guide shows you how.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Nishiki Aero II Front Inner Tube Replacement, Removing Road Bike Front Wheel: passo 1, immagine 1 di 1
    • Turn the bike upside down.
  2. Nishiki Aero II Front Inner Tube Replacement: passo 2, immagine 1 di 1
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Front Inner Tube Replacement: passo 3, immagine 1 di 2 Nishiki Aero II Front Inner Tube Replacement: passo 3, immagine 2 di 2
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Front Inner Tube Replacement: passo 4, immagine 1 di 1
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Front Inner Tube Replacement: passo 5, immagine 1 di 1
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Front Inner Tube Replacement, Nishiki Aero II Tire Removal: passo 6, immagine 1 di 2 Nishiki Aero II Front Inner Tube Replacement, Nishiki Aero II Tire Removal: passo 6, immagine 2 di 2
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Front Inner Tube Replacement: passo 7, immagine 1 di 3 Nishiki Aero II Front Inner Tube Replacement: passo 7, immagine 2 di 3 Nishiki Aero II Front Inner Tube Replacement: passo 7, immagine 3 di 3
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Front Inner Tube Replacement: passo 8, immagine 1 di 2 Nishiki Aero II Front Inner Tube Replacement: passo 8, immagine 2 di 2
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Front Inner Tube Replacement: passo 9, immagine 1 di 3 Nishiki Aero II Front Inner Tube Replacement: passo 9, immagine 2 di 3 Nishiki Aero II Front Inner Tube Replacement: passo 9, immagine 3 di 3
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Front Inner Tube Replacement: passo 10, immagine 1 di 3 Nishiki Aero II Front Inner Tube Replacement: passo 10, immagine 2 di 3 Nishiki Aero II Front Inner Tube Replacement: passo 10, immagine 3 di 3
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
  11. Nishiki Aero II Front Inner Tube Replacement, Front Inner Tube: passo 11, immagine 1 di 1
    • Now that the tire and tube are off of the rim, gently pull the tube out of the tire.
    • Be sure to pull gently, as the tube could potentially end up adhered to the inside of the tire.
  12. Nishiki Aero II Front Inner Tube Replacement: passo 12, immagine 1 di 1
    • Now, you've separated your tube, tire and rim.
    • To replace the tube, follow these instructions in reverse order using the new or patched tube.
    • Remember to inflate just a little bit of air into the tube before you try to install it, as that makes the process go much smoother.
Conclusione
Tobias Elder
Membro da: 04/25/13
113 Reputazione
7 Guide realizzate
Cal Poly, Team 21-53, Johann Spring 2013 Membro di Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,539
