Salta al contenuto principale
Nintendo Wii Remote Speaker Replacement
Cosa ti serve
  1. Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: passo 1, immagine 1 di 2 Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: passo 1, immagine 2 di 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    Chiedi a FixBot
  2. Nintendo Wii Remote Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    Chiedi a FixBot
  3. Nintendo Wii Remote Speaker Replacement: passo 3, immagine 1 di 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    Chiedi a FixBot
  4. Nintendo Wii Remote Speaker Replacement: passo 4, immagine 1 di 2 Nintendo Wii Remote Speaker Replacement: passo 4, immagine 2 di 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Chiedi a FixBot
  5. Nintendo Wii Remote Speaker Replacement, Speaker: passo 5, immagine 1 di 3 Nintendo Wii Remote Speaker Replacement, Speaker: passo 5, immagine 2 di 3 Nintendo Wii Remote Speaker Replacement, Speaker: passo 5, immagine 3 di 3
    • Place the plastic opening tool between the edge of the speaker and the wii remote.
    • Gently lift the speaker out of the body of the Wii remote.
    Chiedi a FixBot
Conclusione
Altre 2 persone hanno completato questa guida.
Emily
Membro da: 04/14/13
2.010 Reputazione
6 guide realizzate
Cal Poly, Team 3-44, Amido Spring 2013 Membro di Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Membri
29 guide realizzate
2Commenti sulla guida
Thank you, u help me to fix it.
joon lew - Rispondi Condividi
That's cool and all, but what speaker am I supposed to buy?
Shadow - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 35
Ultimi 30 giorni: 202
Tutti i Tempi: 9,392
