Salta al contenuto principale
Nintendo Wii Nunchuk Control Stick Replacement
Cosa ti serve
  1. Nintendo Wii Nunchuk Control Stick Replacement, Control Stick: passo 1, immagine 1 di 1
    • Clean and disinfect the Nintendo Nunchuk with disinfectant wipes to remove any bacteria, dust, or stains.
  2. Nintendo Wii Nunchuk Control Stick Replacement: passo 2, immagine 1 di 2 Nintendo Wii Nunchuk Control Stick Replacement: passo 2, immagine 2 di 2
  3. Nintendo Wii Nunchuk Control Stick Replacement: passo 3, immagine 1 di 1
    • Remove the top cover of the Nunchuk by pulling it off with your fingers.
    • Be careful not to pull too hard on the cover so that you do not accidently dislodge the parts inside the Nunchuk. You may need to apply some more force if your Nunchuk is an older model.
  4. Nintendo Wii Nunchuk Control Stick Replacement: passo 4, immagine 1 di 1
    • Remove the central control stick by tugging on it until the control stick slides off the slot.
    • You may need to pull harder on the control stick if your Nunchuk is an older device.
  5. Nintendo Wii Nunchuk Control Stick Replacement: passo 5, immagine 1 di 1
    • Attach the new stick by inserting either the Nintendo Wii Nunchuk Control Stick or a Gameboy Controller Control Stick onto the nub.
    • Make sure that the stick is securely and firmly inserted.
Conclusione
Altre 2 persone hanno completato questa guida.
Sky Ye
Membro da: 01/09/24
175 Reputazione
1 Guida realizzata
2Commenti sulla guida
Cómo reparar el botón del control de wii que queda dentro y no sale ni gunciona
Fredy rosado - Replica
Dans le cas de la Wiimote ou du Nunchuk, il sera nécessaire d'ouvrir le boîtier pour voir ce qui provoque ce problème. Pour nettoyer, utilisez un coton tige et de l'alcool isopropylique.
AreUBready -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 110
Tutti i Tempi: 2,074
