Salta al contenuto principale
Nintendo 3DS Cartridge Reader Replacement
Abraham Zapata
Abraham Zapata e 10 altri collaboratori
Ultimo aggiornamento il March 30, 2025
40 minuti - 1 ora
Difficile
Vigilanza sulla Grammatica
Pallini!
Testo Confuso
Necessarie Più Immagini
Introduzione Migliore
Studente al lavoro
Introduzione
Vai al passo 1
This is a step-by-step guide on how to replace the cartridge (game card) reader so you can get back to enjoying playing those nostalgic games on the go. This guide is meant for Old 3DS models.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Nintendo 3DS Cartridge Reader Replacement, Opening the Cover: passo 1, immagine 1 di 1
    • Use a JIS #00 screwdriver to loosen the four screws along the top of the back cover. These screws stay in the cover after loosing them.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is designed to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
  2. Nintendo 3DS Cartridge Reader Replacement, Opening the Case: passo 2, immagine 1 di 2 Nintendo 3DS Cartridge Reader Replacement, Opening the Case: passo 2, immagine 2 di 2
    • Remove all 10 screws to access the third layer and the motherboard of the 3DS. Don't forget the one near the game card slot, it is silver, not black.
    • Carefully open up the next layer of the 3DS pulling from the bottom
    • Be carful when opening. Ribbon on the top cables are delicate.
    • Leave screws to the side for later reassembly.
  3. Nintendo 3DS Cartridge Reader Replacement, Release the Cartridge Reader: passo 3, immagine 1 di 3 Nintendo 3DS Cartridge Reader Replacement, Release the Cartridge Reader: passo 3, immagine 2 di 3 Nintendo 3DS Cartridge Reader Replacement, Release the Cartridge Reader: passo 3, immagine 3 di 3
    • To release the cartridge reader look for 4 solder points, 2 on each side of the reader (see image).
    • Apply heat to them with a soldering iron to melt the solder and take out the reader. Use a spludger to lift the reader out of the board as you apply heat.
    • You can apply some solder flux or even some new solder wire to form an alloy between the old and new metals, this would ease the task.
    • CAUTION: Soldering iron can cause severe burns if not used properly, proceed with caution and have an adult in the room with you if underage.
  4. Nintendo 3DS Cartridge Reader Replacement, Solder the New Cartridge Reader: passo 4, immagine 1 di 1
    • Now that the game cartridge reader is out, lets get the new one in. Line it up with the previous one and re-solder it using a soldering wire.
  5. Nintendo 3DS Cartridge Reader Replacement, Cleaning up: passo 5, immagine 1 di 1
    • Before closing off the device use Isopropyl alcohol and a q-tip and clean the surrounding area, removing all flux residues.
    • After cleaning you are good to reassemble your device.
    • Use isopropyl alcohol in a well ventilated room.
Conclusione
Abraham Zapata
Membro da: 03/05/24
145 Reputazione
1 Guida realizzata
1Commento della guida
It might help to utilize a prerequisite guide up until the actual replacement of the cartridge slot. The IR board replacement is short and similar in step number in this regard.
Russ9876 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 60
Ultimi 30 Giorni: 249
Tutti i Tempi: 1,832
