Salta al contenuto principale
Nikon Coolpix S9050 Menu Wheel and OK Button Replacement
Catrionna Bruce
Catrionna Bruce e 6 altri collaboratori
Ultimo aggiornamento il January 9, 2025
10 minuti
Moderato
Introduzione
Vai al passo 1
If your Nikon Coolpix S9050 is not turning on, the menu wheel and OK button may need to be replaced. The requirements for this procedure are to have a Phillips #000 screwdriver and a flat surface to disassemble the parts. Make sure the camera is off and it is recommended to work in a dry area.
Cosa ti serve
Strumenti
  1. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: passo 1, immagine 1 di 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: passo 1, immagine 2 di 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: passo 1, immagine 3 di 3
    • Using a Phillips #000 screwdriver, remove the two 3.2mm black screws on both sides of the camera.
    • Set the camera face down and remove the four 3.2mm silver screws using the same screwdriver.
  2. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: passo 2, immagine 1 di 1
    • Remove the display frame and trim from the main body of the camera.
  3. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: passo 3, immagine 1 di 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: passo 3, immagine 2 di 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: passo 3, immagine 3 di 3
    • Press down and pull the Menu Wheel/OK Button panel toward the screen.
    • This releases the panel from the slots.
  4. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: passo 4, immagine 1 di 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: passo 4, immagine 2 di 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: passo 4, immagine 3 di 3
    • Lift the black plastic tabs, which are securing the panel.
    • Gently pull the panel out to separate the display ribbon cable from the camera body.
Conclusione
IUPUI, Team S3-G3, Harley Fall 2018 Membro di IUPUI, Team S3-G3, Harley Fall 2018
IUPUI-HARLEY-F18S3G3
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 553
