Nikon Coolpix S9050 LCD Screen Replacement
Introduzione
Vai al passo 1Overtime, the components in a camera are likely to fail or become faulty. One component that may become faulty overtime is the screen. If your camera is not properly displaying the images you’ve taken or if there are dead pixels on your screen, the screen may need to be replaced. This guide will assist you in replacing the LCD Screen on the Nikon Coolpix S9050.
Cosa ti serve
Using a Phillips #000 screwdriver, remove the two 3.2mm black screws on both sides of the camera.
Set the camera face down and remove the four 3.2mm silver screws using the same screwdriver.
Remove the silver 3.2 mm Phillips #000 screw on the corner of the device to remove the screen.
