Salta al contenuto principale
Nikon Coolpix S51c Lens Replacement
Ryan
Ryan e 11 altri collaboratori
Ultimo aggiornamento il June 15, 2023
20 minuti
Moderato
Guida In Evidenza
Studente al lavoro
Introduzione
Vai al passo 1
If your Nikon Coolpix S51c camera is producing photos that are blurry or show scratches or marks on the photo, the camera lens may be damaged. You can replace the camera lens by following this guide.
Disconnect your camera from its charger before starting this repair. There are delicate ribbons and wires inside the camera, so be careful not to rip them.
Cosa ti serve
Strumenti
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Nikon Coolpix S51c Lens Replacement, Back Cover: passo 1, immagine 1 di 2 Nikon Coolpix S51c Lens Replacement, Back Cover: passo 1, immagine 2 di 2
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
  2. Nikon Coolpix S51c Lens Replacement: passo 2, immagine 1 di 1
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Lens Replacement: passo 3, immagine 1 di 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Lens Replacement: passo 4, immagine 1 di 1
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Lens Replacement: passo 5, immagine 1 di 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
  6. Nikon Coolpix S51c Lens Replacement, Lens: passo 6, immagine 1 di 3 Nikon Coolpix S51c Lens Replacement, Lens: passo 6, immagine 2 di 3 Nikon Coolpix S51c Lens Replacement, Lens: passo 6, immagine 3 di 3
    • Remove the five screws on the metal plate.
    • One of them is in a hole in the corner of the metal plate.
    • Remove the screw at the bottom of the camera.
    • Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
  7. Nikon Coolpix S51c Lens Replacement: passo 7, immagine 1 di 2 Nikon Coolpix S51c Lens Replacement: passo 7, immagine 2 di 2
    • Lift the white flap with the spudger to release the ribbon.
    • Remove the back metal plate.
  8. Nikon Coolpix S51c Lens Replacement: passo 8, immagine 1 di 3 Nikon Coolpix S51c Lens Replacement: passo 8, immagine 2 di 3 Nikon Coolpix S51c Lens Replacement: passo 8, immagine 3 di 3
    • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
Conclusione
Ryan
Membro da: 04/12/11
155 Reputazione
6 Guide realizzate
Cal Poly, Team 18-24, Garner Spring 2011 Membro di Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Membri
6 Guide realizzate
2 Commenti
question: any source for replacement lens block ? can't find any on the internet
Cyrille Dupuydauby - Replica
question: any source for lens block ? I can't find any on the internet
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,543
