Salta al contenuto principale
Nikon Coolpix S4100 External Casing Replacement
Matthew Willis
Matthew Willis e 6 altri collaboratori
Ultimo aggiornamento il July 29, 2020
7 minuti
Facile
Inconveniente Markup
Necessarie Più Immagini
Introduzione
Vai al passo 1
In this guide, you will find instructions on how to properly remove the entire external casing of the camera. This guide will reveal the inner components of the camera. From here, you can replace the casing if it is broken, or access other internal parts of the camera.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nikon Coolpix S4100 External Casing Replacement, External Casing: passo 1, immagine 1 di 3 Nikon Coolpix S4100 External Casing Replacement, External Casing: passo 1, immagine 2 di 3 Nikon Coolpix S4100 External Casing Replacement, External Casing: passo 1, immagine 3 di 3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
  2. Nikon Coolpix S4100 External Casing Replacement: passo 2, immagine 1 di 1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
  3. Nikon Coolpix S4100 External Casing Replacement: passo 3, immagine 1 di 1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
  4. Nikon Coolpix S4100 External Casing Replacement: passo 4, immagine 1 di 3 Nikon Coolpix S4100 External Casing Replacement: passo 4, immagine 2 di 3 Nikon Coolpix S4100 External Casing Replacement: passo 4, immagine 3 di 3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
  5. Nikon Coolpix S4100 External Casing Replacement: passo 5, immagine 1 di 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
  6. Nikon Coolpix S4100 External Casing Replacement: passo 6, immagine 1 di 2 Nikon Coolpix S4100 External Casing Replacement: passo 6, immagine 2 di 2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
  7. Nikon Coolpix S4100 External Casing Replacement: passo 7, immagine 1 di 3 Nikon Coolpix S4100 External Casing Replacement: passo 7, immagine 2 di 3 Nikon Coolpix S4100 External Casing Replacement: passo 7, immagine 3 di 3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
  8. Nikon Coolpix S4100 External Casing Replacement: passo 8, immagine 1 di 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
  9. Nikon Coolpix S4100 External Casing Replacement: passo 9, immagine 1 di 1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
  10. Nikon Coolpix S4100 External Casing Replacement: passo 10, immagine 1 di 1
    • Remove the remaining side shell casing.
  11. Nikon Coolpix S4100 External Casing Replacement: passo 11, immagine 1 di 1
    • Remove the top shell casing.
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team 4-2, Williams Fall 2015 Membro di Baylor, Team 4-2, Williams Fall 2015
BU-WILLIAMS-F15S4G2
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,055
