Salta al contenuto principale
Nikon Coolpix S3500 Rear Buttons  Replacement
Jordan Rosemeyer
Jordan Rosemeyer e un altro collaboratore
Ultimo aggiornamento il July 26, 2020
1 - 2 minuti
Molto facile
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
The guide will show you step by step on how to replace the rear buttons of this device.
Cosa ti serve
Strumenti
  1. Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: passo 1, immagine 1 di 2 Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: passo 1, immagine 2 di 2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Nikon Coolpix S3500 Rear Buttons  Replacement: passo 2, immagine 1 di 2 Nikon Coolpix S3500 Rear Buttons  Replacement: passo 2, immagine 2 di 2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Nikon Coolpix S3500 Rear Buttons  Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S3500 Rear Buttons  Replacement: passo 3, immagine 2 di 2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Nikon Coolpix S3500 Rear Buttons  Replacement: passo 4, immagine 1 di 2 Nikon Coolpix S3500 Rear Buttons  Replacement: passo 4, immagine 2 di 2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Nikon Coolpix S3500 Rear Buttons  Replacement: passo 5, immagine 1 di 3 Nikon Coolpix S3500 Rear Buttons  Replacement: passo 5, immagine 2 di 3 Nikon Coolpix S3500 Rear Buttons  Replacement: passo 5, immagine 3 di 3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Nikon Coolpix S3500 Rear Buttons  Replacement: passo 6, immagine 1 di 2 Nikon Coolpix S3500 Rear Buttons  Replacement: passo 6, immagine 2 di 2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
  7. Nikon Coolpix S3500 Rear Buttons  Replacement, Rear Buttons: passo 7, immagine 1 di 1
    • Take the rear panel of the device in the palm of your hand with the buttons facing downward.
  8. Nikon Coolpix S3500 Rear Buttons  Replacement: passo 8, immagine 1 di 3 Nikon Coolpix S3500 Rear Buttons  Replacement: passo 8, immagine 2 di 3 Nikon Coolpix S3500 Rear Buttons  Replacement: passo 8, immagine 3 di 3
    • On the back side of the device's rear panel, you will see the plastic brackets that hold the rear function buttons in place.
    • With your other hand, take the pry tool and start working your way around the edge of the buttons
  9. Nikon Coolpix S3500 Rear Buttons  Replacement: passo 9, immagine 1 di 2 Nikon Coolpix S3500 Rear Buttons  Replacement: passo 9, immagine 2 di 2
    • Now, take the hand that was previously holding the pry tool, and finish pulling off the rear function buttons.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 487
