Salta al contenuto principale
Nikon Coolpix S33 Motherboard Replacement
Maria Frias
Maria Frias e 3 altri collaboratori
Ultimo aggiornamento il July 24, 2020
35 minuti
Moderato
Introduzione
Vai al passo 1
If your camera won't respond to any efforts to turn on, you may need to replace the motherboard in the camera. This guide will walk you through how to replace the motherboard so that you can have a working camera again.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Nikon Coolpix S33 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 2 Nikon Coolpix S33 Motherboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove battery before initiating this step to avoid the possibility of electric shock.
    • Remove all four T5 Torx screws from the exterior of the camera.
    • Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
  2. Nikon Coolpix S33 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the two screws located above the HDMI and USB logos that are inside the camera's battery compartment using a JIS000 screwdriver.
  3. Nikon Coolpix S33 Motherboard Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S33 Motherboard Replacement: passo 3, immagine 2 di 2
    • Using a plastic opening tool, gently remove the back cover from the camera.
  4. Nikon Coolpix S33 Motherboard Replacement, LCD: passo 4, immagine 1 di 1
    • Be sure to have followed the steps to remove the Back Cover of your camera before beginning to replace the LCD Screen. This guide will cover just the replacement of the LCD Screen.
    • Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
  5. Nikon Coolpix S33 Motherboard Replacement: passo 5, immagine 1 di 1
    • Before pulling the LCD Screen out of the camera, you will need to disconnect the ribbon connector that attaches the screen to the camera.
    • Gently pull the ribbon connector out of it's slot. You should be able to remove it without the need of any tools.
  6. Nikon Coolpix S33 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 Nikon Coolpix S33 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Remove all three 15'' Torx screws. Gently pry off the LCD holder using a plastic opening tool.
    • Peel off the connecting tape under the LCD holder to disconnect it completely.
  7. Nikon Coolpix S33 Motherboard Replacement: passo 7, immagine 1 di 1
    • Peel back black electrical tape and disconnect the ribbon connectors from the mother board.
    • Disconect the wires from the motherboard.
    • Take out the two 15'' Phillips screws, as shown in the image, using a Phillips screwdriver.
  8. Nikon Coolpix S33 Motherboard Replacement: passo 8, immagine 1 di 1
    • Gently pry off the motherboard using a plastic opening tool.
Conclusione
Altre 5 persone hanno completato questa guida.
Maria Frias
Membro da: 02/18/16
564 Reputazione
4 Guide realizzate
USF Tampa, Team 16-3, Blackwell Winter 2016 Membro di USF Tampa, Team 16-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,502
