Salta al contenuto principale
Nikon Coolpix S3100 Camera Disassembly
Jorge
Jorge e 4 altri collaboratori
Ultimo aggiornamento il January 8, 2018
30 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
If you happened to drop camera into dirt or sand, this guide will explain to you on how to clean it.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: passo 1, immagine 1 di 3 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: passo 1, immagine 2 di 3 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: passo 1, immagine 3 di 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Disassembly: passo 2, immagine 1 di 2 Nikon Coolpix S3100 Camera Disassembly: passo 2, immagine 2 di 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Disassembly: passo 3, immagine 1 di 2 Nikon Coolpix S3100 Camera Disassembly: passo 3, immagine 2 di 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: passo 4, immagine 1 di 2 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: passo 4, immagine 2 di 2
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the orange board to the right. (picture 2)
  5. Nikon Coolpix S3100 Camera Disassembly: passo 5, immagine 1 di 3 Nikon Coolpix S3100 Camera Disassembly: passo 5, immagine 2 di 3 Nikon Coolpix S3100 Camera Disassembly: passo 5, immagine 3 di 3
    • Lift screen up holding the corners.
    • Gently pull to the left to release from ZIF connector. (picture 2)
    • Gently pull the orange board to the right. (picture 3)
  6. Nikon Coolpix S3100 Camera Disassembly: passo 6, immagine 1 di 2 Nikon Coolpix S3100 Camera Disassembly: passo 6, immagine 2 di 2
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the shutter up. (picture 2)
  7. Nikon Coolpix S3100 Camera Disassembly: passo 7, immagine 1 di 2 Nikon Coolpix S3100 Camera Disassembly: passo 7, immagine 2 di 2
    • Lens is now separated from body.
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  8. Nikon Coolpix S3100 Camera Disassembly: passo 8, immagine 1 di 3 Nikon Coolpix S3100 Camera Disassembly: passo 8, immagine 2 di 3 Nikon Coolpix S3100 Camera Disassembly: passo 8, immagine 3 di 3
    • Use a nylon or metal spudger to release the lens.
    • Repeat step 4 to the opposite side of the lens. (picture 2)
    • Lens is now separated from metal.
  9. Nikon Coolpix S3100 Camera Disassembly: passo 9, immagine 1 di 3 Nikon Coolpix S3100 Camera Disassembly: passo 9, immagine 2 di 3 Nikon Coolpix S3100 Camera Disassembly: passo 9, immagine 3 di 3
    • Once you have all the parts separated, start cleaning them with an air compressor bottle. (as shown)
    • Using the provided straw, start spraying the parts. (pictures 2 and 3)
Conclusione
Altre 2 persone hanno completato questa guida.
Jorge
Membro da: 03/11/15
1.170 Reputazione
7 Guide realizzate
Un commento
accidentally touched the wires for the cap even though i read the warning, can confirm, not fun
zettabyte - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 59
Tutti i Tempi: 3,508
