Salta al contenuto principale
Nikon Coolpix S230 LCD Screen Replacement
Chris Helms
Chris Helms e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
10 minuti
Moderato
Introduzione
Vai al passo 1
Is the LCD screen on your Coolpix S230 cracked or damaged? This guide will walk you through how to replace it.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nikon Coolpix S230 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Nikon Coolpix S230 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Nikon Coolpix S230 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Ensure the camera is turned off and the battery is removed.
    • Using a Phillips #000 screwdriver, remove the four 2-mm screws from the side of the camera.
    • Remove the two 3-mm screws from the other side of the camera.
    • Finally, remove the three 4-mm screws from the bottom of the camera.
  2. Nikon Coolpix S230 LCD Screen Replacement: passo 2, immagine 1 di 3 Nikon Coolpix S230 LCD Screen Replacement: passo 2, immagine 2 di 3 Nikon Coolpix S230 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tool into the seam where the front and back parts of the case meet on the bottom of the camera, and slide it along the bottom. Continue along the next side to separate the back part of the case.
    • If necessary, continue along the third and fourth sides until the case separates easily.
    • Lift the back off of the case.
  3. Nikon Coolpix S230 LCD Screen Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S230 LCD Screen Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Carefully lift the LCD screen to reveal two orange ribbons connecting the screen to the camera.
    • Use tweezers to carefully lift the blue retaining flap holding down the orange ribbon cable. (Flap can be seen open in the second photo)
    • Slowly wiggle the ribbon cable back and forth while pulling away from the zero insertion force (ZIF) connector to disconnect the cable.
  4. Nikon Coolpix S230 LCD Screen Replacement: passo 4, immagine 1 di 2 Nikon Coolpix S230 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Using tweezers, lift the black retaining flap holding down the larger orange ribbon cable.
    • Carefully remove the ribbon cable from the ZIF connector as before.
  5. Nikon Coolpix S230 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Lift the LCD screen away from the camera.
Conclusione
Baylor, Team 3-1, Whitney Spring 2017 Membro di Baylor, Team 3-1, Whitney Spring 2017
BU-WHITNEY-S17S3G1
4 Membri
8 Guide realizzate
Un commento
How do you put in a new LCD screen . Also what should I do if I turn on my camera and touch screen doesn’t work and it just says set time and date but you cannot click any options.
emilia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 787
