Salta al contenuto principale
Nikon Coolpix S210 LCD screen Replacement
Mallory Arend
Mallory Arend e 7 altri collaboratori
Ultimo aggiornamento il July 18, 2020
Nessuna stima
Moderato
Guida In Evidenza
Introduzione
Vai al passo 1
You will be removing the back casing of the camera. You will need a Phillips #00 screwdriver and a spudger. You will then be directed to remove screws.
Cosa ti serve
Strumenti
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Nikon Coolpix S210 LCD screen Replacement, Battery: passo 1, immagine 1 di 1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 LCD screen Replacement: passo 2, immagine 1 di 2 Nikon Coolpix S210 LCD screen Replacement: passo 2, immagine 2 di 2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Nikon Coolpix S210 LCD screen Replacement, Back Case: passo 3, immagine 1 di 1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 LCD screen Replacement: passo 4, immagine 1 di 1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 LCD screen Replacement: passo 5, immagine 1 di 1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 LCD screen Replacement: passo 6, immagine 1 di 2 Nikon Coolpix S210 LCD screen Replacement: passo 6, immagine 2 di 2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 LCD screen Replacement, LCD screen: passo 7, immagine 1 di 3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: passo 7, immagine 2 di 3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: passo 7, immagine 3 di 3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 LCD screen Replacement: passo 8, immagine 1 di 1
    • Gently remove the LCD screen.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 5-17, Amido Winter 2011 Membro di Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 Membri
12 Guide realizzate
Un commento
Funcionou conforme descrito! Funciona para a Nikon Coolpix S203
geral - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,166
