Salta al contenuto principale
Nikon Coolpix P90 Battery Replacement
Elizabeth Kamine
Elizabeth Kamine e 5 altri collaboratori
Ultimo aggiornamento il July 2, 2024
1 minuto
Molto facile
Introduzione
Vai al passo 1
Follow this guide to replace the battery of your Nikon Coolpix P90 camera with a fully charged EN-EL5 rechargeable Li-ion battery. It provides 3.7V and 1100mAh. Check your battery to ensure you are replacing with a compatible model.
Make sure that your camera is off and unplugged from the charger before you begin this repair.
  1. Nikon Coolpix P90 Battery Replacement, Camera Base: passo 1, immagine 1 di 3 Nikon Coolpix P90 Battery Replacement, Camera Base: passo 1, immagine 2 di 3 Nikon Coolpix P90 Battery Replacement, Camera Base: passo 1, immagine 3 di 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
Conclusione
Cal Poly, Team 20-14, Maness Winter 2015 Membro di Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,184
