Nikon Coolpix P510 Lens Casing Replacement
Introduzione
Vai al passo 1This guide uses the lens assembly guide to get the camera apart. Once you have finished with the lens assembly, getting to the casing is fairly easy.
Cosa ti serve
Strumenti
Mostra di più…
Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
On the thumb grip, remove the one 4mm PH00 Philips screw.
Altre 3 persone hanno completato questa guida.
